![]() | Home > Off Topic > Computer Help |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8129 ![]() ![]() ![]() |
What is the data on - a USB drive ?
drakes Member Since: 26 Jan 2009 Location: Consett Posts: 373 ![]() ![]() ![]() |
Alastair
I guess it really depends what they could recover - did they give you any kind of report ?
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
I don't think you want two bootable partitions on the same drive. Yes, it CAN be done but it's easy to mess that up. Also, you said you had all the files recovered from the old drive. Recovery is not always 100% in those cases. If it's a *.doc(x) file and you need to do a little reformatting - no big deal. I'd it's the OS and you're missing a few bytes, that could be a big problem. Keep the personal files, definitely, but I'd recommend a fresh install for all recovered programmes. |
Thanks for the replies, yes it is only the data files I have got back so I will copy them into the new install.
