Home > Maintenance & Mods (L322) > L322 td6 diff help.
Show n shine
United Kingdom 2002 Range Rover Vogue Td6 Adriatic Blue
L322 td6 diff help.
Guys what tools are required to open diff sump and fill plugs. That's for front and rear please.
Cheers
Post #390754 8th Jun 2016 1:52pm
Weegie
14 mm allen key. There isn't a lot of clearance at the front so I use a short socket/allen key. Torque setting
Front Differential:Oil drain plug 65 Nm 48 lbf.ft
Oil filler/level plug 45 Nm 33 lbf.ft
Rear: Oil drain plug 65 Nm 48 lbf.ft
Oil filler/level plug 65 Nm 48 lbf.ft
You also need some threadseal for the filler plug (Loctite)
Remember make sure the filler plug is loose before draining. Wink John
GAP iiD BT-Sold
Post #390783 8th Jun 2016 4:06pm
Show n shine
Thumbs Up Cheers pal.
Post #390808 8th Jun 2016 6:45pm
