![]() | Home > Maintenance & Mods (L322) > Rear Passenger door will not unlock with keyfob |
Is your childlock not activated on that door |
Declan303 Member Since: 08 Dec 2015 Location: Meath Posts: 151 ![]() ![]() ![]() |
No checked that, Same as far side that does open. As I say, I can open it from inside so not child lock Declan
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 361 ![]() ![]() ![]() |
Hi EmiratesA380,
Great help, thanks again. |
Anyone got a wiring diagram for the door locks so I can test it before buying a new one just in case its a wiring problem. Declan
Declan, do it sooner rather than later sir... Once the latch fails locked you;; be into cutting things open |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
Don't bother fiddling about with it. I had to replace both rears on my td6...... It'll be the latch.... Fit a new one...... Quick as Craig says....
Is LR013381 the correct part number of what needs to be replaced. rear passenger side door. I happened to look on ebay and found Range Rover L322 03-09 Left Driver Side REAR Door Lock Latch Actuator CWC500090 so a bit confused |
Anyone know is the latch and the actuator two seperate part numbers or are they all the one unit? Declan
Got sorted, pulled the latch/activator out and part number is CWC000111 which apparently is superseded by LR013381 so new one ordered. Hope the old one holds out till it arrives |
Leave it unplugged until the new one arrives |
Yeah good idea, I didn't think of that. Might just open it again and pull the plug off |
