Home > Technical (L322) > Whirring noise from engine bay
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
I've just started to service my 3.6 TDV8 and noticed a quite loud whirring (maybe squealish) kinda noise from the engine bay, when the ignition is on.
I haven't noticed this before, for 2 reasons
1 - never had the bonnet open with the ignition on until today
2 - maybe never heard the noise with the bonnet shut before, as I'm deaf as a door post Mr. Green
Soooo, is it normal?? I thought maybe diesel lift pump, but the noise is there all the time. (Thought the lift pump would stop after a minute or so)
I have just changed the diesel filter, which was a royal ass pain.
Any help appreciated, as ever
Cheers
Post #390902 9th Jun 2016 11:45am
i wouldnt worry, theres always weird sounds coming from there...... ... - .- -.
Post #390903 9th Jun 2016 12:03pm
mr_spock
Could be the cabin heater aux water pump. This is supposed to do that, and is a great help bleeding the V8 petrol engines.
Post #390906 9th Jun 2016 12:26pm
If it's all the time it could be the cooling fan for the ecu box, the big black one, it has a cooling fan in the bottom and a temp sensor, cools the ecu's when it gets hot... The fan's are known to dry up and squeak a bit, if you take the lid off it would confirm it... gave mine a blast of penetrating fluid and it's shut up since.... Pete
Post #390908 9th Jun 2016 12:41pm
cheezels
Ok will check that. Cheers for that.
'Tis quite loud, 'tever 'tis
Post #390909 9th Jun 2016 1:09pm
