Home > Technical (L322) > Steering Wheel tilt Mechanism
SHasson1690
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
Hi was wondering if anyone would have any idea why the tilt mechanism on my RR wont work ? Have no idea as to why, thanks in advance.
Post #390660 7th Jun 2016 11:17pm
its broken.......theres a lot about this, have a search Thumbs Up ... - .- -.
Post #390674 8th Jun 2016 6:10am
SHasson1690
Thanks
Post #390683 8th Jun 2016 7:17am
Clivefog
Expensive replacement plastic part from a chap in Germany fixed it for me, far cheaper than replacing the complete mechanism and a home job to boot.
Post #390795 8th Jun 2016 5:10pm
1959terry
United Kingdom 2015 Range Rover Vogue SE SDV8 Santorini Black
This Is the part i believe
http://www.ebay.co.uk/itm/191891434321?_tr...EBIDX%3AIT
Terry 2015 Range Rover VSE 4.4 SDV8. 1998 BMW 840 Sport, 2008 Aston Martin DB9
2009 Triumph Bonneville, 1959 Triumph Bonneville, 1969 Triumph Bonneville, 1975 T160 Triumph Trident, 2014 Suzuki Gladius, 1990 Harley Davidson Fat Boy.
Post #390832 8th Jun 2016 8:37pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
The poster is asking about Tilt , not reach so that part is not involved. The Tilt has a weak point where the a piece of metal snaps off which in the worst case leaves the steering wheel in your lap. Question is has it ever worked in your ownership? if so it could be seized, motor stuffed, turned off etc. If it has never worked it could be the previous owner has done a modification after the tilt metal part has broken off. Easy enough to take off the steering column cover to see whats going on.
http://www.rangerovers.net/repairdetails/steering/tilt3.html 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #390871 9th Jun 2016 3:36am
SHasson1690
Sorry for the misunderstanding, neither the reach or tilt mechanism work, this was like this when I bought the car.
Happy to clear up my mistake
Post #390944 9th Jun 2016 6:49pm
If you remove the steering column shroud (three T20 torx screws, you need a screwdriver not a socket to reach them) then you can manually adjust it with either an allen key in the end of the gear screw or a flatblade screwdriver depending on which type you have...
Bit of a pain if you have more than one driver but it is possible... Thumbs Up Pete
-Click here for Thread-
Post #390947 9th Jun 2016 7:20pm
Mr bump
United Kingdom 2006 Range Rover Vogue SE Td6 Java Black
Did you resolve your problem as mine is exactly the same . The stalk does nothing at all
Post #395924 13th Jul 2016 7:19pm
It's a well known failure, if it's not physically broken then the motors give up, they are a fortune to buy, several places around doing reconditioned units but they are still expensive.... Thumbs Up Pete
Post #395926 13th Jul 2016 7:29pm
Mr bump
Oh ok , not quite the same as mine then. My colum works as adjusts to previous owners settings when you press the memory buttons but the stalk does nothing. Hoping it may just be a stalk fault, need to get a replacement and fingers crossed.
Post #395928 13th Jul 2016 7:32pm
Oh I see... OP's didn't work at all so not quite the same, you're in luck, will probably be the stalk which is much cheaper than the motors... result... Thumbs Up Pete
Post #395930 13th Jul 2016 7:37pm
