Home > Maintenance & Mods (L322) > A "thingamabob"
Boydonegood
United Kingdom 2004 Range Rover Vogue Td6 Ipanema Sand
A "thingamabob"
Hi all
L322. The heat shield has fallen off between exhaust and boot floor. The holes in the heat shield have rusted to around 1 inch, but the "pegs" that hold it up are still there.
My theory is to put it back up with penny washers and hold it in with a "thingamabob"!!!
Seriously tho, what do you call the twist on washer/fasteners? I thought they were called Spire clips but seems not when trying to buy some. And am looking a bit stupid as the man in the shop has no idea what I'm on!! Embarassed They kind of push/twist onto slight threaded pegs to hold non structural things together.
Pic of peg
(Well done to anyone that understands that!!)
Thanks in advance
Tel Accept, some days your the pigeon, some days your the statue!
Post #391106 10th Jun 2016 8:05pm
Weegie
Mine came off 18 months ago. Still waiting in the workshop. Might not bother now. Wink John
GAP iiD BT-Sold
Post #391107 10th Jun 2016 8:14pm
espaceboy
I used these on my audi tt under plastic
http://www.ebay.co.uk/itm/221864954810
Post #391116 10th Jun 2016 8:47pm
Boydonegood
Weegie, if it weren't for the not knowing how hot it's gonna get driving 800 mile to Spain soon, I'd bin it as around locals it don't make any difference..
Espaceboy, thanks fella!!! Close but not exactly what I had in mind but would do perfectly well I think! They may be the route to go down! Thank you.
The ones I had in mind were like a thin pressed tin with a nut shape pressed in it with a large split hole in.
Damn I know that don't make sence!!! I reckon your call is better!! Thanks!
Post #391121 10th Jun 2016 8:55pm
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
I have one lying about the garage, car never went on fire without it!
Post #391134 10th Jun 2016 9:30pm
Boydonegood
Is pointing more and more to the skip!!! Accept, some days your the pigeon, some days your the statue!
Post #391135 10th Jun 2016 9:35pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
http://www.sdproducts.co.uk/self-threading-nuts-washer-type
http://www.ebay.co.uk/itm/BMW-Self-Tapping...1019906068
Bit of a rip off though. Spire clips would work or Starlock washers.
Post #391148 10th Jun 2016 10:54pm
Boydonegood
Weejock. The "posts" arnt proper threaded so can't get nuts on them, so no go on the spires or star washers.
But, the other things are exactly what I was looking for!! Thanks buddy!! Will order them in morning! Your a star!
Thanks to everyone for help. As always
Post #391151 10th Jun 2016 11:10pm
Weejock
Official part number WYH500050
Bit cheaper than BMW ones above:
http://www.brit-car.co.uk/product.php/1701...rge_spacer
Post #391153 10th Jun 2016 11:20pm
Boydonegood
For a dozen quid I'll order them and put it back on. Thank you so much. Am going to order those ones. Looks like the size of them will be the same as a penny washer. So perfect.
You guys are diamonds. Thank you. Accept, some days your the pigeon, some days your the statue!
Post #391154 10th Jun 2016 11:24pm
nip848
United Kingdom 2002 Range Rover Vogue 4.4 V8 Giverny Green
If the hole gets too big for them, I find cutting up a coke can and adding that under the peg saves it from falling off. Happened on a mondeo i had and the fix worked perfectly.
Post #391408 12th Jun 2016 6:59pm
