![]() | Home > Maintenance & Mods (L322) > Car not being used long term - should I remove battery? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35770 ![]() ![]() |
i would disconnect the battery ...dont forget to turn the steering wheel left/right on re-connection.. ... - .- -.
I agree with Stan, disconnect and still put a trickle charger, one that keeps the battery in good shape.
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8064 ![]() ![]() ![]() |
Can you leave it plugged in on a trickle charger ? |
Show n shine Member Since: 01 Jun 2016 Location: Hertfordshire Posts: 55 ![]() ![]() ![]() |
Google ctek chargers. |
J90 Member Since: 02 Jul 2013 Location: Somewhere south of Bergerac Posts: 651 ![]() ![]() ![]() |
The car is being left outside but I don't fancy the idea of a long cable across the driveway connected to an electrical point inside the house. I like idea of disconnecting the battery and a couple of wooden blocks under the suspension arms.
I have a ctek charger and the various connections. I shall probably remove the battery completely and connect it to the ctek via a socket in an outbuilding. I'm just not happy having the battery in the car whilst connected to a live socket I have no control over for 12 weeks. Travelling around in circles again. |
Show n shine. Are you over on the detailing world forum as well? Travelling around in circles again. |
Mr Tee Member Since: 13 Dec 2010 Location: Near Wackyjim Posts: 2712 ![]() ![]() ![]() |
Disco |
appj62 Member Since: 07 Aug 2013 Location: Cheshire Posts: 424 ![]() ![]() ![]() |
If it is left outside, consider a Solar powered trickle charger. Previous cars:
appj 62 has a point, the solar charger has been discussed in plenty posts on here and seem to work well. That way you only have to worry about the blocks |
take the battery out like you have suggested J90 and its less likely to get stolen... |
Based upon all of your advice I shall remove the battery completely and connect it up to my ctek. I will also put wooden blocks under the suspension arms.
