Home > Maintenance & Mods (L322) > Strange issues...
Danwilderspin
Strange issues...
So like a nutter I jumped in at the deep end and went for a 200 mile drive today (got to do the same on the way back tomorrow)
This is the longest by far I've driven in my week of ownership and I have some strange issues I'm a bit worried about.
Firstly I'm in Wales currently and have been going down some very steep both up and down narrow roads.
First thing I notice squeezing the throttle maybe 3/4 on the incline or decline I notice it was holding the gears for a very long time as in >4K then I was having to slow down so couldn't test further... Is this normal? Or I read somewhere that the trans can over heat on these... I initially thought why would I only see it now but prior to this part for the drive the other 180miles were motorway so I'm guessing if it were that that may cool naturally? I don't know any ideas or is it just normal Smile ?
Secondly I bravely/ stupidly hung my new camera out the window on its neck chain to quickly snap this (not something I make a habit of!) ever since going down a very steep narrow road it's been making that noise looked in tyres nothing obvious - was wondering if you've heard before and if I should worry as I have the same drive to do again to more :'(
Any help would be brilliant
Thanks again!
Post #392370 20th Jun 2016 5:39pm
Holding the gears is a cooling strategy, and also a hill strategy, it will hold gears both up and down hills if it thinks it will help, sometimes it's a pain, sometimes it helps...
Not sure what you took a picture of as nothing is showing in your post......
I'd seriously think about investing in an IID tool or similar, then you can check the gearbox temp and see if it is excessive, if yours has the original radiator and trans oil cooler then the chances are they will need changing soon... Pete
Post #392378 20th Jun 2016 6:23pm
Danwilderspin
http://www.youtube.com/watch?v=moECn9xjuy
Thanks for the advise here's the link I meant to post!
Post #392384 20th Jun 2016 7:07pm
Danwilderspin
Try that again sorry
Post #392385 20th Jun 2016 7:10pm
espaceboy
are your brake shield loose
Post #392391 20th Jun 2016 7:39pm
Danwilderspin
What's the best way to tell with no tools( I have tools at home obviously) turn the wheels and shake the shield if they are accessible? Sorry for silly questions new to this 4x4 business Wink
Post #392392 20th Jun 2016 7:44pm
espaceboy
the brake shields sit behind the brake disks and are thin metal and circular. If they are loose the can rub again the bake disks as they rotate and cause a chuff chuff sound
use a screw driver and through the gaps is the wheel spokes given them a push. you will know if one is loose and rattling
if thats the issue then great, can be fixed with washers.
if not then ..it does sound that something is rubbing at the same speed as the wheels
Post #392395 20th Jun 2016 7:52pm
nicksaab
2016 Range Rover Vogue SE SDV8 Corris Grey
If the noise is coming from a rear wheel its possible a handbrake shoe has dislodged from the backing plate in the hub and is rubbing on the hub - had this before and it made a similar chuffing noise Current Fleet:-
2018 Discovery 5 3.0 HSE
2021 Ford Ranger Wildtrack
2019 Ford Mustang Bullitt 5.0 V8
1993 Defender 90 200TDI Pickup
Gone - not forgotten
2016 L405 4.4 SDV8 Vogue SE
2012 L322 4.4 Westminster
2004 L322 4.4 V8 Autobiography LE
2000 P38 RR 4.0 HSE (ex Clarkson test car)
Post #392400 20th Jun 2016 8:16pm
espaceboy
yup, had that too now that I remember, good call
Post #392402 20th Jun 2016 8:41pm
Danwilderspin
&feature=youtu.be
Hi guys is this normal? just got my hands through and gave them a shake - the rears are solid all around however bot the fronts at the bottom facing the back of the car it can be shaken see/hear my video above - the rest of the way round the are pretty solid?
cheers
Post #392487 21st Jun 2016 9:57am
Danwilderspin
Side note - this forum has been brilliant so far as good as if not better than the M5board which surprised me - so thanks guys Smile on the m5board you can thank users but can't seem to do it on here is there a way? if not would be good to implement Smile
Thanks
Post #392488 21st Jun 2016 9:59am
Stuart
United Kingdom 2011 Range Rover Vogue SE TDV8 Santorini Black
Dan - had both front heat shields come loose on my 54 reg - one of them just as I got to the dealer's to ask for a part ex price!
They rust around the bolt heads. Easy fix with washers. Thumbs Up
Post #392497 21st Jun 2016 10:58am
Danwilderspin
Hi Stuart do the videos indicate that's the problem? I bent them a bit and the noise has gone so I can get home so I think it is or a stone was trapped I imagine
Post #392508 21st Jun 2016 12:17pm
Stuart
My heat shields had rusted through in the area surrounding all three (or four?) bolt heads, so mine were rattling and clanging all the time the wheel was turning.
Yes, it did sound like the noise in your second video (but not like the noise in your first video) - but it may be that only one bolt head has rusted through on yours?
Sorry to hear of your issues, Dan, and hope you resolve them.
Post #392523 21st Jun 2016 2:09pm
Fretless
Scotland 2011 Range Rover Vogue TDV8 Baltic Blue
Maybe also check the heat shielding above the exhaust rear box - could be flapping around in the breeze. Long shot, but you never know... The best 4.4 x far
Post #392530 21st Jun 2016 3:17pm
