Home > Maintenance & Mods (L322) > Engine flush and fuel additive
cheezels
Australia 2007 Range Rover Vogue TDV8 Java Black
Thought I'd post my experience of a couple of products from a local company called Cost Effective Maintenance.
I bought some of their engine flush and fuel additive and have to say I'm impressed.
The fuel additive has made the engine noticeably quieter, a little more responsive and a tad more frugal.
The engine flush required new oil and fast idling for about 30 minutes. The oil that came out was slightly thicker than what went in and blacker than black (after on 30 mins). So obviously the flush had flushed pretty good.
After a 1000 kays the oil is still clear on the dipstick.
Just out of bi curiousness I did remove both oil drain plugs after losing suction on the vacuum pump I use to remove the oil from the engine. Probably a mug full of oil came out, so the vacuum doesn't quite get everything out.
Anyhoo, I don't work for these guys but certainly recommend the products.
Post #392514 21st Jun 2016 12:50pm
What engine...???
If you fill in your car details in your profile you will get a little FF in your side bar, when you hover the curser over it it shows what FF you have... Thumbs Up Pete
Post #392549 21st Jun 2016 7:48pm
cheezels
Already done that when I signed up Shocked
But in any case it's a 3.6 tdv8 2007 3.6 TDV8
Post #392582 22nd Jun 2016 3:02am
cheezels
And have added a signature to be sure, to be sure 2007 3.6 TDV8
Post #392583 22nd Jun 2016 3:02am
Something wrong as you don't have the little car emblem...!!! Pete
Post #392602 22nd Jun 2016 8:35am
rar110
Gday mate
PM me the details. I might give it a go. I'd rather see clear oil on the dipstick.
Also I've just started giving emulators a go. The motor runs quieter and produces almost no smoke with a boot full.
Ta. ______________________________
Post #392617 22nd Jun 2016 10:13am
cheezels
PM'd 2007 3.6 TDV8
Post #392619 22nd Jun 2016 10:36am
cheezels
OMFG!!
How do I enable the little car emblem!
Big Cry
I give in 2007 3.6 TDV8
Post #392621 22nd Jun 2016 10:42am
ebajema
Lets hope Stan can help you out.
The input is quite particular so you need to select everything you can select. Sometimes we find out that a certain colour or spec is not available and then it won't go up but if all boxes are selected, it should normally work. MY 2010 5.0 SC Galway green and sand interior!!
Post #392632 22nd Jun 2016 12:34pm
^ what Eugene says, all the boxes must be filled in.. ... - .- -.
Post #392637 22nd Jun 2016 1:32pm
steptoe
Re: Engine flush and fuel additive
Engine flush is simply ATF fluid packaged in smaller containers and sold for 10 times the price.
Add a litre of ATF, run engine for 15 minutes before draining the oil.
Post #392763 23rd Jun 2016 12:30pm
johnboyairey
...add ATF to oil, or fuel, (or gearbox!) ?
Post #392766 23rd Jun 2016 12:51pm
steptoe
Engine... The clue is in the Post " ENGINE flush is simply ATF fluid packaged in smaller containers and sold for 10 times the price". Very Happy
Post #392805 23rd Jun 2016 7:02pm
