|  | Home > Technical (L322) > So called Diff' wind up |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | I think diff wind up applies to the older systems, whereas ours tend to be more open diffed, with traction control taking up the slack.... May be wrong. I know some early Defenders (not really Defenders, the Series ones) and like mk1 Shoguns have the issue in 4wd, which is why it's not recommended for on road use.
|  22nd Jun 2016 4:35pm |
| espaceboy Member Since: 02 Aug 2014 Location: Fae Fife Posts: 86      | you don't have diff lock | ||
|  22nd Jun 2016 4:53pm |
| Weejock Member Since: 30 Dec 2011 Location: UK Posts: 419    | Diff wind up happens on locked diffs, when one output side cannot rotate at a different speed to the other on a high grip surface the diff will 'wind up' and can lead to broken half shafts, diffs etc. It's the equivalent of having a solid steel bar and trying to twist one end more than the other, something will eventually break. It's why you don't use locked diffs on tarmac roads.
|  22nd Jun 2016 5:02pm |
| Posting Rules
