![]() | Home > Technical (L322) > Suspension fault - Lowering to the bump stops while driving |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
Sounds like a re calibration could be in order, I think it's recommended when changing a height sensor.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8715 ![]() ![]() ![]() |
Sounds to me like you have another sensor out, probably due to the dropping to the stops when the first one went, when old they don't like going outside their normal range....
WoddyRR Member Since: 01 May 2016 Location: Shropshire Posts: 13 ![]() ![]() ![]() |
Hi,
Thanks Haylands,
4x4 info on flat ground, the orange blocks are not perfectly straight.
Not much point changing another sensor without finding out which one is giving trouble, the garages "change them in pairs" does not apply to these, they are not an item that needs changing in pairs, they are just a very cheap hall effect sensor put in a box with JLR on it and sold for a ridiculous amount...
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2725 ![]() ![]() |
Near enough IS good enough as the suspension ecu doesn't know how level the ground is. |
Thanks both, yes I should really invest in a diagnostics tool, I like the sound of the AllComs system, but at the moment I need this sorted asap and the tool from the States to the UK is time for me. It went back in today, and they say the other rear left height sensor was -30 out of range. So I replaced that, and still the same, the guys say it will be recalibrated and then something to do with some software/coding update (the adviser wasn't a 100% sure) as I have had the 3 pin sensors on the rear which superseed from my original 6 pin sensors. I'm not convinced that what they are saying will rectify the problem. I'm loosing faith a little bit.
Are all the heights on roughly the same level on the 4x4 display when at access height? |
Yes roughly, but not all perfectly the same?
I wondered if one or more sensor signals became erratic when away from normal height but obviously not. |
Which would indicate a faulty height sensor? They all seem OK, there really must be something else that's shutting the EAS system down I just wish the local specialist would do a thorough diagnostic check.
Whilst not the same air suspension system, the D4 WSM states that lowering to the bump-stops will occur for "Failure of multiple height sensors, cross-articulation when driving, calibration corrupted". I wonder if the motorway calibrations have been corrupted.
