Home > Technical (L322) > HELP
ALAN JONES
HELP
warning light has appeared on dashboard air suspension inactive...
can anyone help?
thank you
Post #393639 29th Jun 2016 2:36pm
no need to post in capital letters, i've converted them to lower case.... ... - .- -.
Post #393640 29th Jun 2016 2:39pm
ALAN JONES
thanks stan
Post #393645 29th Jun 2016 2:52pm
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Maybe a mechanic ?
Whistle
Post #393650 29th Jun 2016 5:08pm
CS
If the car seems to be working normally you might try seeing what it does in the morning. My 2004 car showed that message from time to time and it just went away again. It can happen because the air compressor has got too hot and needs a break, it is OK again once it has cooled.
If you keep getting the warning it might be a sensor that has broken, that can happen at random, a diagnostic test would reveal which one. Only Range Rovers since 1988
Post #393678 29th Jun 2016 7:27pm
RR2008HSE
Good advice from CS. I'm no expert, but it seems like too little info to diagnose.
Post #393744 29th Jun 2016 11:07pm
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Same as CS. My 2007 SC used to randomly display that error message from time to time but usually cleared itself.
Not sure that's massively helpful, but as is the way with all things tech nowadays "turn it off and then turn it back on again" can cure many ills.
Also maybe get the suspension 'air bags' checked. If they get minor leaks / failures I believe the loss of pressure can throw up your error message too. Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #393746 29th Jun 2016 11:15pm
Bluegreygreen Rangie
Australia
Without an id tool etc there is nothing you can really do as you must be able to see the fault codes as a first step, I have the Gap diagnostic tool and highly recommend it
I have already used it to diagnose a faulty steering angle sensor which was causing my eas / abs etc inactive codes, I then replaced the sensor myself and re set it using the tool and all has been good for some 50 thousand odd ks, The tool in all honesty will pay for itself the first time you have a problem like this
Actually thinking about it more , One thing you can do is check your battery voltage / condition and that the terminals are nice and tight... low voltage etc can cause these type of issues also
Dave
Post #393802 30th Jun 2016 11:06am
