![]() | Home > Technical (L322) > Rear ride hieght sensor L322 td6 vogue 2005 |
Brydo Member Since: 11 May 2016 Location: Scotlannd Posts: 17 ![]() ![]() ![]() |
When using my All comms diagnostics tool to check air suspension levels the near nearside is giving a level of 0. Is there a problem with this ride height sensor. Any help will be most welcome. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8739 ![]() ![]() ![]() |
Don't have an all comms so don't know, what do the others say..??
the aii comms gives a value of between 8 and 5.8 for the other sensors but 0 for n/s rear. I can clear the fault code but when on uneven ground air suspension inactive returns. My rr sits higher at the rear than the front ( off road level. |
You didn't mention you had a fault showing...
Thanks Pete. I'm new to rr so need all the help I can get |
Read all the features in the WIKI , download Rave the workshop manual and put your anorack on.... |
