Home > Technical (L322) > Strange noise on unlocking...
This started a few days ago, if the car has gone to sleep after the 16 minute shutdown then this noise happens for a few seconds after unlocking and waking the car up again, does it with the door open or closed, it is triggered by unlocking... Coming from the lower centre console..
I'm thinking its some HVAC flap trying to open or move in some way, I can't make it happen, tried all different settings, HVAC is working fine, nothing else not working...
Anyone any ideas before I start ripping it apart...?????
 Pete
-Click here for Thread-
Post #393899 30th Jun 2016 7:46pm
MR GLOVER
United Kingdom 2005 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
think that means you need 55plate sc pete Very Happy
Post #393904 30th Jun 2016 8:02pm
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Sounds like something is slipping over a cog pete, similar to when a window mechanism goes.
I think your on the right track with the flaps.
good luck with the fix.
now you've done it, we'll all be having it. Laughing
greg. Thumbs Up
Post #393905 30th Jun 2016 8:05pm
Love one Paul, when you price yours sensibly at £3000 I'll have it... Whistle
Greg, yep sounds just like it but why does a flap shut or open when the car goes to sleep and move again when it opens but not when you use the HVAC... Pete
Post #393919 30th Jun 2016 9:05pm
DrAvalanche
I have something similar... rapid and at a continuos pace for about five seconds or so. Doesn't happen all the time though so haven't really investigated it... Current:
2000 4.0V8 (LPG) P38 in Rioja red
2003 4.4 V8 (LPG) in Java black
2005 BMW Mini Cooper Park Lane in Royal grey
Gone:
2002 4.6V8 (LPG) P38 in Epsom Green
2002 4.4V8 Petrol (LPG) L322 in Giverny Green with Ivory interior
Post #393925 30th Jun 2016 9:34pm
gregdav
I've always noticed on mine when I open the door, there's always a noise like the heater motor, doesn't last for long.
can't be more specific as it's always done it, so I thought it's just an rr thing. I wonder if it's a weather thing like shuts the flaps when shut down, to prevent damp air getting in, thenwhen awakened , weather dependant, opens again.
on some old previous cars I had, I used to manually put the heater to hot and shut all flaps and vents, it helped stop icing up in a morning on the inside. Of course technology has moved on, so it may do it automatically.
Just a thought.
hope you get it sorted as it sounds annoying.
Greg.
Post #393929 30th Jun 2016 9:41pm
Sandyt
Mine makes a noise like the pre heater motor runs for about 15 secs but that noise Pete sounds like a ratchet slipping very odd
Post #393931 30th Jun 2016 9:48pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
That is the motor that controls the HVAC flaps, remove the panel and it's the round unit with the white writing on, rev,I've the unit and you and reseat it, issue shout go away after that mine did.
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos âžž YouTube.com/RangeRoverOwner
Post #393934 30th Jun 2016 10:09pm
Thank you all for the help and Matt for the fix, I presumed someone would have heard it before, we are away for the weekend doing some new lanes up near Newcastle so it will have to wait till next week..... Pete
Post #393949 30th Jun 2016 10:52pm
gregdav
Post #393963 1st Jul 2016 6:30am
Matt, you were spot on with which motor it was, I unplugged it and it stopped the noise, I then thought I'd try all the different settings on the HVAC panel and everything works as it should so what does this thing do... any ideas....???? Pete
Post #395854 13th Jul 2016 12:56pm
Mikeyjd
Wales 2003 Range Rover SE Td6 Zambezi Silver
Mine has always made a noise like that after it has been standing for a while, only for not so long (a couple of seconds). I just assumed it was something to do with the onboard computer firing up. It has been doing it for years with no ill-effect, No longer FF owner but still interested. Present car Jaguar XE
Previous car Td6 SE
Previous LR- Disco 300TDi Auto
Post #396474 17th Jul 2016 1:11pm
uteman
Australia 2003 Range Rover HSE Td6 Zambezi Silver
Rear Face Level temperature blend motor
I am aware that the original post is quite old but why start again?
My 2003 L322 TD6 starting making the same "clacking" noise from the heater assembly area.
I tracked it down (with help) to the "Rear Face Level Temperature Blend Motor"
See item 5 on page 82-14 of the L322 workshop manual.
With the power feed to that motor removed there is no noise.
I then reconnected the power and unclipped the motor from the heater housing and held that in my hand after opening the car which had been closed for some time.
The motor appeared to run smoothly and certainly there was no noise.
Then I tried to load up the motor by gripping the drive end end firmly in my hand to see if that load would bring about the noise. It did not.
Right now the motor is back in place but power feed removed resulting in no temperature control to rear face level heater.
Has anyone found that by replacing the motor that the problem goes away or is there something more sinister going on inside the heater assembly housing?
Post #469131 18th Feb 2018 7:08am
