Home > Maintenance & Mods (L322) > L322 Rear side windows in boot compartment
anorakmark
United Kingdom 2004 Range Rover Vogue Td6 Epsom Green
Good day all, some quick advice needed regarding the two rear left & right windows in the tailgate area.
I have noticed on the right window O/S there are two small wires that attach to the bottom of the window with solder. Both mine on the right hand window have come adrift. Can anyone tell me if these wires are for the heated window as both windows have the wires running through the glass, so I'm asuming they are anti demist element. The two soldered wires are they for the demist element or radio antenna? I was guessing the radio antenna was on the roof the shark fin? Also is there anyway of re-soldering these back on and how do you access them, I have attached a photo of the offending wire. Any advice would be great thank you.
Mark.
Post #394018 1st Jul 2016 3:34pm
they are radio antennas in the rear sides Mark.. ... - .- -.
Post #394019 1st Jul 2016 3:42pm
anorakmark
Thanks Stan, now any idea how to re-attach these & removing the trim to access?
Post #394021 1st Jul 2016 3:44pm
AM or LW i think...???
Post #394066 1st Jul 2016 10:25pm
anorakmark
Thanks Cam-Tech-Craig.
Am I thinking that the FM and GPS is run to the sharks fin on the roof?
Any info on how to remove the rear trim to access the broken wire that's adrift would be great.
Post #394071 1st Jul 2016 10:36pm
