![]() | Home > Technical (L322) > Suspension leaning but no faults and no leaks, calibratedx4 |
| Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6434
Keep going and soon you will have changed all the parts on the suspension |
| JohnJ Member Since: 22 Apr 2016 Location: Varese Posts: 41
thanks, forgot to mention that yes, I did check the wheel alignment with the sensors (4 kind of checkerboards linked to the wheels) and all looked fine.
| Nicka2311 Member Since: 29 Dec 2012 Location: Scotland Posts: 51
Sounds like a pin hole leak at the top of the right bag which is only exposed in off road height or long periods of use when compressor will stop running to prevent overheating.
thanks Nicka, tomorrow I will check. But when you say jack it up do you mean to put the car on jack, or just to put in on high suspension settings (off road mode) and switch off engine to listen for leakage? |
Lift into off-road mode and Jack to get air Spring fully extended and then listen for leaks, can also run soapy water on the bag as it will bubble of air is escaping '55 Java Black Vogue |
| All times are GMT |
