Home > Wheels & Tyres > What happens to TPMS on wheels on a L322
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
am looking at some 22" wheels from a L405 to fit on my L322, but a lot seem to have TPMS fitted, what happens to this when fitted to the L322? Unsure of how it works?
(Not fussed if it doesnt work, is is a case of just not connecting it up?)
Post #394106 2nd Jul 2016 8:37am
Do you have TPMS on your L322 ?
The car needs the system installed to work. If you don't have it, then the valves in the wheels will just do nothing. You need the sensors in the wheel arches.
If you do have it, then the earlier wheels are compatible with the L322 system, but the L405 got a new system around a year ago, so new valves are not backwardly compatible.
Post #394107 2nd Jul 2016 8:45am
mrblonde
Mines a 2003 TD6 so pretty sure it hasnt got it (to my knowledge anyway)
So I can just fit the L405 wheels and leave the valves in as they are? Just didnt want to buy a set of wheels and have to spend out more getting them modified or something because of the TPMS
Post #394118 2nd Jul 2016 9:55am
Correct - just fit them as normal Thumbs Up
They are basically a metal stemmed valve that bolts in & has a small box of electronics on the inside of the wheel.
Perfectly fine to leave there - of whenever you get new tyres, you could remove them & have rubber valves fitted.
They used to have a problem with corrosion and valves snapping at >5 years or so old - so I'd be tempted to swap them out anyway if you don't need them, but certainly no rush to do that.
Post #394141 2nd Jul 2016 12:48pm
mrblonde
Thats great, many thanks Alistair, think I'll treat myself to a set this weekend.
Do you know what type of wheel bolts I will need?
Post #394146 2nd Jul 2016 2:13pm
Bolts fall into 2 categories and are wheel specific.
The 05 and earlier wheels had a narrower shank than the 06 and later wheels - the thread was the same, but the bore on the wheels was different. If you use old bolts on new wheels, they will shake themselves loose - so get the right ones Thumbs Up
Some images on this thread Thumbs Up
Post #394172 2nd Jul 2016 7:47pm
