Home > Technical (L322) > High level brake light morse code
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
Hi.
The high level brake light on my 03 ff sometimes only has half of the led's working,
sometimes all of them, sometimes none of them (current configuration). Is this going to be
just a replacement unit job or is there something deeper in the ff's brain that could be causing
the problem? QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #394176 2nd Jul 2016 8:11pm
RR2008HSE
Are the LEDs in series? That could cause problems if some are on their way out. Can you get a new light with a good return policy? That way, if you plug it in and all is good - GREAT. If not, the problem lies elsewhere and just return the new light.
Good luck.
Post #394184 2nd Jul 2016 8:46pm
