![]() | Home > Technical (L322) > Door Card with Door Deadlocked |
Sleeper Member Since: 01 Jun 2016 Location: Birmingham Posts: 55 ![]() ![]() ![]() |
As far as i know as long as you have removed all the screw then it will be a case of getting something like a mini crowbar in behind the doorcard and the door.
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Maybe, if you take off the opposite door card, pretending to not use the edges, you might figure it out.
Rosco Member Since: 20 Jan 2012 Location: Beyond the wall. Posts: 2591 ![]() ![]() ![]() |
I had exactly the same issue last year, there is a way in without wrecking the door card but involves removing rear door then access is gained by removing a grommet which you will see with rear door open, but access is very tricky/impossible without door removal, eventually gave it to a garage to do |
Nicka2311 Member Since: 29 Dec 2012 Location: Scotland Posts: 51 ![]() ![]() ![]() |
Thanks for responses,
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16398 ![]() ![]() ![]() |
Have you tried a battery disconnection/reset yet? That may help???
Hi Craig,
Goldy Member Since: 24 Mar 2016 Location: Bolton Posts: 77 ![]() ![]() ![]() |
Slightly off topic but my RR has damage to both driver and passenger inside sills, like something has been trying to get the door open.
No I dont but there are definite 'crowbar' marks along the internal B pillar ![]() |
That was actually an easy job, the full door card doesn't even have to come off, no damage to door card or B pillar just enough to remove the door airbag and go into the door behind it to break the latch.
