![]() | Home > Maintenance & Mods (L322) > Occasional 'Suspension fault' |
Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227 ![]() ![]() ![]() |
I get similar, but in any situation not just sitting in traffic.
Busa1400 Member Since: 05 Oct 2015 Location: Leeds Posts: 112 ![]() ![]() ![]() |
I agree entirely, the reason for posting was for a general conflab, it would be a very quiet site if we all simply got the codes read and fixed the problem |
Colin44 Member Since: 20 Mar 2016 Location: Dornoch Posts: 6 ![]() ![]() |
Before replacing the compressor remove the gold colour cone silencer from it and try that mine was blocked, had same problem and even more if I had a trailer on, can't remember the code it gave but I only found the awnser by googling the code and found lots of info about remove or replace it, it worked for me so I just left it off |
I had the top off the compressor unit - All seems very clean.the car had just been driven and the compressor was not that hot which is good.
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Well try going to Neutral and putting the handbrake on when at rest (best practice!) See if that makes a difference?
Sorry been mental busy.
Nicka2311 Member Since: 29 Dec 2012 Location: Scotland Posts: 51 ![]() ![]() ![]() |
The compressors shut off automatically to prevent overheating (error message appears on dash to a similar description) so I wouldn't imagine you would feel excessive heat off of one. The plastic piston ring inside the air compressor will wear out eventually. I got about 100,000 miles out of mine but a pin hole leak in o/s/f causing excessive work load on compressor speeded up failure in my opinion. Are there any leak noises coming from bags when raised and on a jack? That's when I discovered my leak '55 Java Black Vogue |
Thanks
