![]() | Home > Camping, Caravanning and Holidays > Roof Rack Options - Wise guidance required |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
I'm a Thule fan - I did 1000's of miles with them on mine in various combinations of 4 bikes / kayaks / roof box / skis & snowboards with no problems at all.
| Jase71 Member Since: 13 Apr 2016 Location: Mona Vale Posts: 494
Thanks Alistair. It's interesting as I found a place to hire the thule racks and a roof box to save them sitting about and they told me they have added the L322 RR to the 'no fit list' which doesn't make sense to me as the Thule website lists it!
I worried at first. but mine didn't mark - I placed them towards the rear of each door arch & they seemed fine - the door just closed & the rubbers just flex around them.
| Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800
I can't remember who it was but someone on the forum posted about this a while back that they used the Thule system that goes into the hidden fixings, saying that it fitted well even though Thule don't have it their fitting list. Maybe my memory is awry but I seem to recollect that fitting didn't require snapping of the fixing covers either.
| axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964
Better in every conceivable way than Thule |
Very nice Axle but priced to match! |
| ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1672
For what its worth I have the genuine LR sports bars and they are excellent quality. The fitting is a bit of a fag but once fitted they feel like they could carry the town hall.
Thanks Ajac8. I quite like the Sorts Bars too as they attach to the roof fittings..Did you have to remove the little fitting covers on the roof? I've heard some require the covers to be cut off which would mean they are permanently mounted!
| Elduke Member Since: 22 Apr 2013 Location: Glasgow Posts: 148
AFAIK the sports bars can be fitted with the flaps remaining just opened up.
The little flaps pop up easily and remain vertical on the inner side of the bar foot. They can be a bit fragile but do not need removing. They simply click back down into place after the bars are removed.
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8788
I have a set of sports bars and they are easy to fit, each foot simply has a Torx screw which screws into a threaded hole in the roof. Dead easy.
| Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3284
@Jase71,
Ah Dolphin Boy, that is hugely kind! I bought the thule ones with the aero bar on the weekend and I've only just seen your kind offer..%^$% !!
Again if you want three bars you have to get the rhino Rack sports bars because they are the only ones that are adjusted for height and width so you can have a flat run to fit trays and the like . 2008 MY Supercharged
