Home > In Car Electronics (L322) > 2010 Locked Screen
andrew-a
2010 Locked Screen
I have a locked screen - On-Off button flashing orange ans "RANGE ROVER" permantently on the screen.
I suspect that it was a blue tooth problem as my son was trying to connect his phone to the car at the time. The screen then shut down and now wont come back on normally.
I read on here that you need to by pass the Bluetooth received in the boot. Is that still the answer?
Thanks
Post #394418 4th Jul 2016 4:47pm
i would leave for a few hours and try again, this will let everything shut down properly...if this doesnt work try a battery disconnection.. ... - .- -.
Post #394438 4th Jul 2016 5:35pm
andrew-a
Re: 2010 Locked Screen
Thanks! Is there a set proceedure for the battery disconnection?
Post #394440 4th Jul 2016 5:40pm
in the wiki Wink ... - .- -.
Post #394442 4th Jul 2016 5:41pm
sako243
I'd check the Bluetooth module for water ingress. If you remove the passenger side boot side then the Bluetooth module us the blue thing on top.
Mine behaved the same way and since I didn't use it that much I simply removed it and bypassed it with a Biro. Ed
Post #394504 4th Jul 2016 8:57pm
andrew-a
Guys,
Happy to report that the problem is fixed as a result of Stans battery disconnection. I only got as far as the first step, disconnecting the earth lead but adhering to the time intervals, and reconnecting it, as I wasn't sure how to proceed....Thankfully that did the trick so it's all working now.
Thanks again Thumbs Up Thumbs Up
Post #394520 4th Jul 2016 10:12pm
