Home > Maintenance & Mods (L322) > Water coming from drain hole?
DannyH
England 2002 Range Rover HSE 4.4 V8 Zambezi Silver
Anyone know where this drain hole is from? Had a fair bit of water coming out of it the other day but I've not been swimming in it so I'm guessing it's rain that got into somewhere in the boot and leaked out after I've been driving.
Just above the rear wheel axle, back of car is to the left of the picture. Yes I've got non standard exhaust on it.
Water was dripping pretty quick out of the drain hole and onto the cross member (hence why the cross member is very wet looking) Dan
2002 Zambezi Silver
Men And Motors RR Quote - It's like having wheels fitted to your living room!
Post #394547 5th Jul 2016 7:55am
DannyH
so no one knows what the hole is above the rear wheel cross member?
Guess I'll have to strip everything out of the boot to see if there is water inside anywhere then.3 Dan
2002 Zambezi Silver
Post #394728 6th Jul 2016 7:24am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Hi looks like one of the bungs out of the boot in the spare wheel pan. You should be able to see if you remove the spare wheel.
greg Thumbs Up
Post #394732 6th Jul 2016 8:36am
DannyH
thanks greg, after doing a quick search it looks like I'm going to be buying some decent sealant and attacking the boot seal.
Or at least I hope it's the seal as I don't want water coming from anywhere else.
I'll keep you posted. Big Cry Dan
2002 Zambezi Silver
Post #394857 7th Jul 2016 7:22am
