Home > Technical (L322) > TD6 Turbo boost probs Resolved
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
It's my month for problems it seems,
The turbo pipe from the intercooler keeps 'blowing off' at the intercooler end - I'm woundering if there is to much pressure? - checked and it appears to be running at max of 220kpa - (30psi) - Can anyone advise on what it should be (or what theirs is)
Much apreciated.
Simon
Post #394044 1st Jul 2016 7:42pm
wayneg
Australia 2007 Range Rover Vogue SE TDV8 Java Black
Not sure what the symptoms of the turbo vanes sticking are but might be worth investigating along with the MAP sensor
http://www.bmwforums.info/general-guides-a...ssues.html 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
1966 Series 2a with V8 conversion gone
Post #394560 5th Jul 2016 10:39am
RP123
Thanks for the though wayneg - thankfully it was a easy fix.
So it looks like the normal operating pressure of @ 30 odd psi is correct for the TD6 turbo. After removing the under trays I noticed the intercooler pipe was hanging off , In typical fashion it hasn't been designed with a simple jubilee clamp but with spring loaded 'clip' that located onto a shoulder/ grove on the intercooler itself. (Photo of pipe and clip in position)
Trouble was my clip was missing and I could not get a replacement clip - so had to buy a whole intercooler pipe and then re fitted the 0.0001p clip onto the old pipe. (I thought about replacing the pipe as well however access to the turbo is a massive job so , if the pipe splits in the future I have a spare!
So I fitted the clip , put the pipe back on the cooler with a nice 'click' , put all the under trays back on and (yes you've guessed it it blew off again as the boost increased) - Back to square one!!
Long story short my missing clip had actually corroded and failed leaving a segment in the grove of the cooler, thus the new clip didn't have enough of a grip and then let go. A bit of effort and skinned knuckles removed the rusty bit and refitted all ok .
Just though I would let you know what happened in case anyone else suffers a similar issue.
Cheers
Simon
Post #394814 6th Jul 2016 8:13pm
Good to know, thanks Thumbs Up .
Post #394832 6th Jul 2016 9:58pm
wayneg
Thanks for the update, another thing to remember for future reference Thumbs Up 2007 TDV8 VSE
2003 TD6 gone.
2002 P38a gone
1999 P38a gone
1997 p38a gone
1993 VSE gone
1992 VSE gone
Post #394849 7th Jul 2016 3:24am
gregdav
England 2005 Range Rover Vogue Td6 Bonatti Grey
Thanks for getting back. Thumbs Up
Post #394853 7th Jul 2016 6:40am
