Home > Technical (L322) > Filling up with Diesel
CharlieBaja
United Kingdom 2007 Range Rover Autobiography TDV8 Buckingham Blue
So when i go down to the petrol station and fill the FF up the fuel keeps stopping like the tank is full even when its more or less empty. I have checked down the hose and the stopper hasn't deployed, however every time you put the correct nozzle as in Diesel into the refill hose it cuts out, i more or less have to hold the trigger and hose with two hands to get a full fill up, a very laborious task. Any answers here most appreciated.
Post #394843 6th Jul 2016 11:46pm
Put the filler nozzle in upside down Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #394845 7th Jul 2016 12:01am
CharlieBaja
have you seen this before?
Post #394846 7th Jul 2016 12:26am
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Yes, quite a common problem, various threads on here about it 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #394852 7th Jul 2016 6:25am
Try re-setting it anyway incase it's partially deployed - useful thread here Thumbs Up
Post #394862 7th Jul 2016 8:20am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
I find Sainsbury to be the worst pumps for this, esso seem to be much better
Post #394865 7th Jul 2016 9:01am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Insert the filler nozzle at the 9 o'clock position Smile
Post #394867 7th Jul 2016 9:23am
CharlieBaja
So what did Land rover say about this, did they fix it because surely this is a design fault?
Post #394869 7th Jul 2016 10:25am
berkshirelad
United Kingdom 2007 Range Rover Vogue SE TDV8 Tonga Green
I had this when I recently bought my TDV8 - I thought it was a design fault but it turned out that the shutters were just deployed and resetting with the tool results in filling at full pump flow with the nozzle held normally.
Just as well, because it takes so much, I was getting cramp in my hand trying to hold the flow rate down while it filled...
I guess that LR must have expected this issue because they supplied the tool in every RR
Post #394889 7th Jul 2016 3:30pm
