![]() | Home > General > Transmission fluid leaking |
| mercuryf1 Member Since: 13 Jan 2009 Location: Penang Posts: 169
Left my car in the car park for 5 days until today, when I went to the car, I noticed that there was a lot of oil on the floor under the car. Luckily one of the guys working in the car park went under to car to trace the leak and he said that the oil is coming from the transmission.
| dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477
Could try the parts guys at Hillendale - very hepful whenever I've used them:
That's great... thanks!
| IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502
I had a small amount of transmission fluid on the driveway and when I got underneath the pipes from the gearbox to the cooler were badly corroded and weeping fluid.
I suspect it may be a bigger job then I initially anticipated cos there is a lot of oil under the car. maybe it's best I get a mechanic to come over to check it out so I can order the parts from UK. Thanks for the tip Ian! '01 1.8i Freelander. Grey/ grey
How much were you charged for the whole repair? Replacement of sump plate alone was it expensive? '01 1.8i Freelander. Grey/ grey '06 4.2 S/C Buckingham Blue/ Parchment '15 5.0 S/C SVA Loire blue/ Black |
Total cost was £774 inc labour.
Ian, was it not necessary to replace the gearbox filter also? (as in http://cgi.ebay.co.uk/LANDROVER-RANGE-ROVE...721wt_907) '01 1.8i Freelander. Grey/ grey '06 4.2 S/C Buckingham Blue/ Parchment '15 5.0 S/C SVA Loire blue/ Black |
Yes the filter was changed at the time.
i was also told by my mechanic that the transmission needs some special expensive gearoil ... and lots of it too@! I wonder if that is his way of gently telling me to expect a big fat bill?!! '01 1.8i Freelander. Grey/ grey
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
The ATF is around £15.00 per litre |
Going to collect the car now. Will the the damage very soon. '01 1.8i Freelander. Grey/ grey
Trousers down time, this will hurt you more than me |
Main parts
| All times are GMT |
