Home > Technical (L322) > fbh not come this morn
David
Spain 2007 Range Rover Vogue SE TDV8 Zermatt Silver
i always set my fbh to come on at 9.10 and every day it has done for a week since i set it untill this morn! any ideas?
Post #39489 26th Nov 2010 10:59am
Re: fbh not come this morn
It's a Range Rover, did you really expect it to work Rolling with laughter Rolling with laughter
Post #39491 26th Nov 2010 11:00am
Avi
2006 Range Rover Vogue Td6 Alveston Red
Low on Fuel ? Apologies if i've posted this on my phone and it contains strange spelling and punctuation.. i just can't be bothered to correct it Very Happy
Post #39493 26th Nov 2010 11:11am
David
nope full tank
Post #39494 26th Nov 2010 11:16am
dan_uk_1984
Could be low voltage...
Post #39495 26th Nov 2010 11:18am
Avi
Does it still work when you turn it on manually ?
Post #39498 26th Nov 2010 11:43am
Vogue
or goosed battery,
when my battery needed replacing, the heater wouldn't start - its a fail safe in the system to preserve enough juice in the battery to start the engine.
or perhaps with use every morning over the last few days the alternator hasn't been able to catch up with charge required - especialy if you only do short journeys
Post #39499 26th Nov 2010 11:45am
Vogue wrote:
or goosed battery,
makes a lot of sense.. Thumbs Up ... - .- -.
Post #39500 26th Nov 2010 11:46am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
For all the faults we claim in the system, the low voltage shut down is amazing. It starts by taking out non essential systems, all in order to keep the engine either running, or able to start.
Has anyone studied the way the systems work, it's amazing. For a simple example, if the headlight ECU fails, another ECU will take over and fail the lights to ON Very Happy Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #39600 26th Nov 2010 8:39pm
dan_uk_1984
The Critical systems on the P38 were all double wired to ensure that even if one wire was damaged the other should be able to carry the data.
A lot of thought goes into our cars...
Post #39601 26th Nov 2010 8:56pm
David
It came on this morn !!!
It has go t me thinking if it wasnt below 16 it would of just ventilated ?
Post #39688 27th Nov 2010 11:24am
must have been a computer glitch david... ... - .- -.
Post #39690 27th Nov 2010 11:26am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Mine doesn't switch on.......
I can see a strip down of the FBH coming on..
Post #39695 27th Nov 2010 11:35am
