![]() | Home > Maintenance & Mods (L322) > SC 5.0 Brembo Brake Bleeding |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6382 ![]() ![]() |
Long story short: Brembo brakes are harder to bleed.
Just realised this is in the wrong section:
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35859 ![]() ![]() |
done |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1854 ![]() ![]() ![]() |
Hi Goldstar,
WDRR Member Since: 12 Feb 2023 Location: Glasgow Posts: 27 ![]() ![]() ![]() |
Good shout Gremlin500🤞 |
Nylands Member Since: 08 Sep 2019 Location: Somerset Posts: 200 ![]() ![]() ![]() |
Glad Goldstar raised this.
@Nylands,
Goldstar Member Since: 04 Dec 2021 Location: Reading Posts: 122 ![]() ![]() |
Thanks Gremlin. I should have mentioned that I have an IID - does that do the job of a proper bleed does anyone know? Thanks Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey. |
JayGee Member Since: 27 Jul 2021 Location: London Posts: 3381 ![]() ![]() ![]() |
AFAIK the GAP has an ABS purge function but not sure if this is the same as a full brake bleed function. The main issue for most will also be the fact that the bleed nipples will be galvanicaly seized in the calliper body so bleeding the brakes will be impossible anyway. 2012 TDV8 Vogue (L322) |
You’re not helping my optimism |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
I can't see that changing the front callipers needs a diagnostic tool, I find gravity bleeding works well... Open the bleed nipples, keep the reservoir filled up and wait till it drips out cleanly with no bubbles... always worked for me and this way prevents the system sucking in air..... |
Very helpful thank you. I’ll try bleeding them and see what happens. Cheers Dec 2021- 2010 Facelift TDV8 4.4 AB in Stornoway Grey. |
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 793 ![]() ![]() |
Yes the IID does do a bleed sequence - it even tell you which sequence to bleed the calipers, I can't remember the details of it but I did have to do it twice - I think it was just my inability to follow instructions. |
Gravity bleeding isn't very good with air trapped in the lines as it will simply rise up against the flow. Better than trying to suck fluid out which is the worst method. Pressure bleeding is best IME but you need a good unit that can provide the right amount of pressure and they are not cheap. 2012 TDV8 Vogue (L322) |
