![]() | Home > Technical (L322) > TD6 Gearbox |
| RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1039
Judging by all of the ‘just out of warranty’ (or, in some fortunate cases, still just within warranty) failures reported on the forums for re-manufactured 5L40-E transmissions for TD6 L322s I would say that, as a rule, the source of the original problem (i.e. wear in the valve bodies/pump housing) had not been addressed when the transmission was reconditioned – mainly due to cost. You either need to get specific assurance that the valve body assembly/pump housing has been tested and replaced (or at least fitted with Sonnax valves), or maybe source the valve body assembly yourself.
| Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3276
Phil, a question. In view of the fact that wear in the valve bodies seems to be one of the primary causes of failure in the GM box, would it be a consideration to change the valve body for a Sonnax one whilst the box is still performing? Provided that there is no apparent "glitter" in the oil. John
| Gritstoner Member Since: 15 Apr 2016 Location: Barnoldswick Posts: 10
Cheers Phil, I'll give the company on the Wirral a call tomorrow to see if they have an exchange unit. |
Yes, in principle, I think this would be a sensible approach provided the transmission’s clutch packs were still in serviceable condition. Clearly this is hard to judge without stripping the transmission – all we know is once there’s metallic debris in the fluid/sump it’s too late. Sonnax produce kits for no less than ten different valve locations for the 5L40-E Rear valve body : 1. Low pressure control valve 2. Reverse lockout valve 3. 4-5 shift control valve Front valve body : 4. Feed limit valve 5. TCC regulator apply valve 6. 3-4 shift control valve 7. Safety mode valve Pump cover : 8. TCC control & enable valves 9. Line boost valve 10. Pressure regulator valve so I think it would be necessary to test the bodies on a Hydra-Test machine, or similar, to determine exactly which of the valves requires replacement. Each valve kit costs between £50 and £100 so, together with the labour charge for reaming the bores, this would soon prove uneconomic if more valves are replaced than necessary.
It’s also important to remember that several valves are in the pump cover rather than the valve body assembly so this would also have to be tested. Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
Great. Please let us know how you get on. Phil |
Thanks for that Phil. Having replaced the filter a couple of times it seemed straightforward to replace the valve block with one already "Sonnaxed". Apparently there is probably more to it than that. |
John,
Phil, I didn't take it as negative at all. Constructive rather than negative. |
| vaz Member Since: 15 Jun 2014 Location: Colne, Lancashire Posts: 332
"what is involved with the pump housing?"
Thanks, Steve. I had a look at Rave but wasn't quite sure. |
Yes, the pump housing is bolted to the back of the bellhousing
Thanks, Phil. |
John - no hijack, this is all interesting and useful stuff.
| frikkadel Member Since: 09 Mar 2016 Location: joburg Posts: 56
Thanks for this post. I have just purchased and as Swambo says i did my dues diligence and now after a purchase finding out more.
