![]() | Home > General > Drat, drat and tripple drat!!! |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8723 ![]() ![]() ![]() |
Just don't leave it too long or you will burn the pump out....
rvbush Member Since: 08 Jan 2016 Location: Leamington Spa Posts: 548 ![]() ![]() ![]() |
Thanks, warning noted! It takes a good while to drop when it's parked up, found it by raising to max.
If they notice it, it "should" fail but that's subjective.... |
Parked it up well over an hour ago on normal height and it's still level. I don't think they'll spot it, unless it get suddenly much worse of course, might have to take the chance. Drives:
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Worth a try, but they should jack it on the ramps and that may reveal the leak. There is nothing that can't be fixed with a hammer😜😜
True, but I guess I've still got a week to get it retested, so if it fails I could get the struts done over next weekend then bang it back in the following week.
