![]() | Home > Maintenance & Mods (L322) > Java Black 2002 |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
On your shopping list should be, engine timing lock set. (Camshaft/chain location tools)
kimlahti Member Since: 14 Oct 2015 Location: Oulu Posts: 85 ![]() ![]() ![]() |
timing tool set *check*
I may have exaggerated her enthusiasm. ![]() ![]() Image link test below: [img]https://brjfpq.dm2303.livefilestore.com/y3mRCc3XEhvYmSdP3SyD9zhS1980KmUdpwOzbu5qsAbGmt8DPkN_1GfOE77zkWay8Pz2VHjm3CymxF6hGzc2w2Elg_JEuHJ8YFQ9pG0yGyYK05KL-yDQOA6AiIf8jiiUP1z3x003_9GzfQO_tKi_nBjVbJDlcitYWVrfuVS6Zh7ZQA?width=1024&height=577&cropmode=none[/img] -08 3.6 Vogue -87 951 |
....something else I changed whilst it was all apart, but can be done when all assembled, a very cheap part, were the vanos solenoid return check valves. Look them up, they eventually 'let by' and allow the oil in the vanos cogs, to run back, making them dry in the mornings. So, behind the protruding vanos solenoid, you insert I think an Allen head, to unscrew them, and replace. Only about £5 each x2.
I only changed the o-rings to those check valves. Otherwise they looked nice and clean. |
Yes the return check valve seals are changeable, I think that's what I did.
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
sweet thread, subscribed ! l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Valley pan is also new. Not sure if it had leaked. Valley was covered in black oily crud. |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822 ![]() ![]() ![]() |
Hi, great thread, good to see the inside of the engine, hope I don't get to see mine though.....
Hi, you should be good if coolant and oil stays where they should be. |
Some progress again. Replaced brake line and hose to LH front. Found some surface corrosion from strut tower. Wirebrush and phosphoric acid paint should slow it down. Lot of cavity wax will be added later. |
Dropped oil from transmission and replaced torque converter with remanufactured one and seal of course. |
The links to the before and after covers don't work....
... i would say, that the weld repair, is from the 'naughty method', of replenishing gearbox fluid. ie, if you are man-enough, you drill the TC with a small drill bit, just off the welded edge, and let it drain overnight, you then rotate it just a tad, and wipe with some spriit, and mig-weld the hole. all from underneath. -in situ!
You rebel, you..... |
