Home > Maintenance & Mods (L322) > Gearbox flush
Busa1400
England 2007 Range Rover Vogue SE TDV8 Santorini Black
Gearbox flush
I have booked mine to have it done on Friday, nothing wrong with the box but it seems that prevention is better than cure 2011 Range Rover Vogue SE
Post #395369 10th Jul 2016 4:22pm
kbald
I see you are in Leeds too. Thinking of having mine done. If you don't mind me asking where is it getting done and how much are they quoting? Thanks
Post #395376 10th Jul 2016 5:10pm
Busa1400
I'm actually getting it done at a garage that I know the owner - Automatic Transmissions in Huddersfield - I'm sure there are not unscrupulous garages out there Shocked Shocked but I'd rather know the work has been done rather than someone telling me it has been done.
He will do it whilst you wait, £230 inc VAT 2011 Range Rover Vogue SE
Post #395385 10th Jul 2016 7:21pm
kbald
Thanks sounds like a fair price. Will keep this in mind.
Post #395391 10th Jul 2016 7:36pm
I just had the D3 done at JGS 4x4 in Isham, Kettering, they have a brand new machine and they did a full flush, cleaning solution, then added STP additives into the fill up. Cost £260
Drives SO much better now, no more over revving, clunky down changes etc. The old ATF was black at 86K and had a consistency of water, the new oil going in is a lovely honey colour and more viscous. Discovery 4 HSE
Post #395446 11th Jul 2016 10:35am
frikkadel
South Africa
Sounds good. as soon as i get td6, it will be off for a gearbox oil and filter change. when i test drove it it was buttery smooth.
i wonder if the zf boxes are stronger?
Post #395479 11th Jul 2016 1:03pm
Dave
Just called JGS to enquire on cost for my FFRR, the guy explained the process. I told him he's been recommended by you RRUK, ask for commission next time Laughing
It a 4 hour round trip but i'd rather go to someone that's recommended Dave
2012 Vogue Westminster 4.4
Post #395482 11th Jul 2016 1:54pm
are you having a new filter fitted as well Dave? ... - .- -.
Post #395483 11th Jul 2016 1:58pm
Dave
I didn't ask Stan, so i'll just go for the flush, he's going to email a quote for the flush as the guy that does it at lunch. I'll let you know the cost Dave
Post #395485 11th Jul 2016 2:05pm
frikkadel
South Africa
I heard that one shouldnt apply additives to the gearbox oils.
Well that is for the GM box
Post #395486 11th Jul 2016 2:18pm
@dave, Thumbs Up ... - .- -.
Post #395488 11th Jul 2016 2:29pm
Lots of people add in things like Dr Tranny or STP, they are to reduce heat, improve changes, shuddering etc that are common on older boxes.
Stan, they do not change the filter. The last place who did my TDV8 did not either, this is a polarising subject but with the machine they use, once the old ATF is taken it they then push through a cleaning solution (Don't ask me what specification it is, I saw the bottle but don't remember) and I think he said this was as good as changing the filter. For me, a full fluid change is better than none, even without a new filter and my TDV8 RR that is owned by Fanders is still romping around Europe towing his glider with no issues with over 45,000m on it since I did the flush.
Then the new fluid went in and he reset the gearbox for me. As luck would have it he said there wasn't a single fault code stored on the Discovery which was nice to know. (Previous owner highly unlikely to have known what fault codes are let alone be able to clear them) Discovery 4 HSE
Post #395490 11th Jul 2016 2:32pm
Cost should be the same as mine I'd imagine.
They were a really nice bunch of guys, I'd use them again. Discovery 4 HSE
Post #395492 11th Jul 2016 2:35pm
Would you accept that excuse in your engine? Whistle Rolling Eyes
Post #395631 12th Jul 2016 10:06am
dingg1
But its a gearbox and not an engine and not subjected to the by-products of combustion - so not a fair comparison
no excuse really
Post #395640 12th Jul 2016 10:32am
