Home > Maintenance & Mods (L322) > This maybe expensive
Busa1400
England 2007 Range Rover Vogue SE TDV8 Santorini Black
Mine has done 100,000 miles and is booked in tomorrow for
1. polybelt replacement including the tensioners - no point in stripping down and not replacing tensioners
2. Water pump - as its exposed cheap for OEM pump
3. CV boots - split
4. Ball joint offside - clucking
5. Suspension fault - rear offside sinks fast when parked and occasonal suspension fault
6. Service
It's a great car but just getting t back to where it should be is proving expensive. 2011 Range Rover Vogue SE
Post #395487 11th Jul 2016 2:25pm
Sadly some owners skip parts of the maintenance and only have them serviced as a bare minimum, we collective on here do much more, and hence pay the price.
Worth it though, once you have one that's all good. Discovery 4 HSE
Post #395494 11th Jul 2016 2:40pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
I can vouch for the above! Bought ours 5 years ago with 85.5K on the clock for £11500 with a 'full service history', then discovered later on that it had not been fully serviced for at least 2 years, first major service was painful, new brakes, discs, all rear suspension bushes etc etc, plus a gearbox rebuild and subsequent radiator / gearbox oil cooler replacement, add in a new (water cooled!) alternator, fuel pump and suspension air compressor and our total spend to date is approaching £15k!!
However, it does sail through its MOT every time and apart from a few small issues (new key fob needed, scrape on rear nearside door where wife attacked a solid stone wall with it - she was being hassled by w white van man though!) and the nearside front headlamp being a bit reticent to switch on occasionally, we're getting there with it!
we're now approaching 130K
And they are superb vehicles! Big Cry
Post #395498 11th Jul 2016 3:16pm
Busa1400
I have brought it for £10,400 3 weeks ago with 99,000 on the clock.
So far
4 new tires
new disks and pads all round
changed rear lights to 2012
changed the bluetooth to one from Wiggy
brought replaced nav unit - still not quite right - works 95% of the time suspect TMC getting overloaded
Replaced rear boot seal
new spare wheel and tire
new battery
Ive always wanted one, and driving it is just....... well you know Very Happy Very Happy Very Happy Very Happy 2011 Range Rover Vogue SE
Post #395503 11th Jul 2016 3:43pm
ije44
United Kingdom 2007 Range Rover Vogue TDV8 Barolo Black
Hello Busa1400,
Just interested in your rear light conversion mate, fancy doing that one myself. How much did you pay and from where? Also, did you need a resister pack, if so, which one?
Much appreciated.
Ian
Post #395550 11th Jul 2016 7:36pm
Busa1400
I brought the rear lights from Xenon Bulbs in Bradford. http://www.xenonbulbs.co.uk
Great guys, fitted including all resistors £300 - no canbus errors - drive in drive out.
Must admit spending money on much needed maintenance is one thing - on shiny things is something else Cool Cool Cool 2011 Range Rover Vogue SE
Post #395562 11th Jul 2016 9:05pm
ije44
Busa1400,
That seems a really good price actually. Ive been looking at units from eBay for about £390 and then you have to buy the pack and also fit them, so your deal looks really good.
Any chance of putting a picture up when convenient?
Thanks,
Ian
Post #395581 11th Jul 2016 10:58pm
I would be a little cautious/suspicious at that super low price... I would expect the lights to be Chinese fakes! OE lights cost loads more than that without fitting Whistle Let alone the body mods, drilling, correct fitting and wiring undates necessary Rolling Eyes
Proceed with caution Whistle
Post #395621 12th Jul 2016 9:44am
Busa1400
What is it with you - I have told you that I have had them fitted, with resistors and they work and work well - what is there to be suspicious about ???
I do not know if they were made by and Land Rover technician on hallowed ground wearing cotton gloves, or a chap in Taiwan in his underwear - they work, they look great - they are probably chinese or american or any other country you can think of, they are not 2007 OEM as they were not OEM in 2007
I did proceed with caution, i didn't hear you whistling whilst I did it, and I survived Whistle Whistle Whistle 2011 Range Rover Vogue SE
Post #396115 14th Jul 2016 9:08pm
Busa1400
Back on topic though Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter Rolling with laughter
I had
Air suspension sensor
Ball Joint
Water Pump
Tensioner
2 Pulleys
1 Idler
1 Drive Belt
Remove re face front pads
£624.90 inc parts and labour - Land Rover parts fitted I have the invoices and £150 labour
Im chuffed with that, and no more bonging each time it is idling with suspension fault . 2011 Range Rover Vogue SE
Post #396119 14th Jul 2016 9:12pm
Thumbs Up Thumbs Up Thumbs Up All my spelling errorz are belong to me!
2024 RR Velar
2021 AM new Vantage
Post #396120 14th Jul 2016 9:14pm
