Home > Technical (L322) > Rear wiper not moving
Danwilderspin
HI all - my rear squirt is working fine but the blade wont move- this has never worked - whats the official way to turn in on? ive tried moving the stalks in all ways so petty sure its dead but confirmation would be good.
If indeed it doesn't move but squirt Is ok - where is good to start?
Thanks
Post #395521 11th Jul 2016 4:50pm
if you squirt it should wipe at the same time IIRC.
fairly easy to remove the motor and replace. there are some repair wikis for when it leaks and TBH if you take it out and apart it may be obvious what needs replacing There is nothing that can't be fixed with a hammer😜😜
Post #395526 11th Jul 2016 5:12pm
http://www.fullfatrr.com/forum/topic884-15.html Discovery 4 HSE
Post #395528 11th Jul 2016 5:18pm
