Home > Technical (L322) > Stalling issue...
Danwilderspin
Stalling issue...
Hi all - a new issue has developed today - just to keep track I have done a couple of mods, new rad, thermostat mod, cone filter... These have been on at least a week with no issues so thinking a red herring....
Ok so what's happening is random stalling, it does it regardless of fuel, LPG or petrol, I can go a whole journey LPG off same issue.
So first of all of the 6 times I started it today four of them I started it and programmed in a destination on the nav, in that time it had randomly stalled - hadn't even moved.
Next I was coming to a junction about 10-12 times today and slowly or vastly came to a stop each time it stalled (I would say at 50 percent of times) this is incredibly annoying and a bit dangerous I would think have to move to park then go again etc...
Does this issue sound familiar and any ideas where to start?
Post #395555 11th Jul 2016 8:52pm
RP123
Scotland 2006 Range Rover HSE Td6 Bonatti Grey
Hi
Stalling can quite often due to an imbalance fuel / air mix. Did this happen before you fitted the cone air cleaner? Ty it with the standard air box- Also worth checking to see if there are any lose pipes that should be fitted to the original air box - breathers and this type of thing - having these disconnected may also effect the idle / stalling .
Post #395558 11th Jul 2016 9:01pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Check the MAF, I had this when my MAF had become lose and and disconnected from the air intake pipe
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos âžž YouTube.com/RangeRoverOwner
Post #395561 11th Jul 2016 9:04pm
Danwilderspin
Ok - that's fine I can revert currently bit with the front end mod I've read you have to go the cone route so is there a preferred cone as I'm running generic?
Thanks
Post #395573 11th Jul 2016 9:33pm
Danwilderspin
Faulty MAF according to codes - currently now running disconnected and v very smooth (only temporary of course)
Post #395737 12th Jul 2016 8:33pm
johnboyairey
A pattern part new MAF or a secondhand original one, is only about £30-£40 small price to prove a fault.
When you swap parts, that you might buy on say EBay, you can often sell them on, should they not cure your fault. If you have proved your fault, after time, you can then decide wether to replace with a new one, or run it as-is.
Post #395800 12th Jul 2016 11:44pm
Danwilderspin
I bought a new genuine Bosch one for £71 as I'm fairly confident it is that that the issue
Post #395806 13th Jul 2016 6:57am
