Home > Technical (L322) > TDV8 Fuel Gauge fault
n1cktdv8
So just coming home from work the fuel gauge went from half a tank to empty and a yellow light, then sprung back into action and was on and off for the bulk of the journey. As I left the motorway it went to empty and has stayed there. Got on drive and turned off for 5 mins...went out and it's OK now Neutral
Any ideas? Is this where I put the car details and a bit about myself ?........
Post #395776 12th Jul 2016 10:42pm
in tank sender Thumbs Up
one is not reading right. there are 2 but together on one unit, and the cluster takes an average, if one is duff it throws it toys out of the pram and goes to 0. mine did it on my old 3.6, did it once then was OK for ages then i brimmed it one time and it was Censored from then on and i got it changed.
you can buy the float levels separately but they aren't cheap at about £90 each and the same labour as actually having the whole thing out. There is nothing that can't be fixed with a hammer😜😜
Post #395782 12th Jul 2016 11:14pm
supershuttle
Mine does it intermittently, reading falls to approximately half of what it was. As a "belt and braces" I zero the trip when I fill up and get more fuel after about 350 miles (5L Petrol) I assume that whatever the gauge says if there is fuel in the tank the engine keeps going. It hasn't done it for a while and often clears itself, I am pretty sure there is a Tech Bulletin on it and how to fix it --- I was told it might not be the senders but the wiring Very Happy Geoff
Post #395788 12th Jul 2016 11:23pm
could be the connections in the tank, mine was fixed after changing the senders. I think that its more likely to be part of the rheostat wears out and fails in the range where the fuel level is normaly kept. There is nothing that can't be fixed with a hammer😜😜
Post #395790 12th Jul 2016 11:26pm
n1cktdv8
I never usually brim the car (full but never to the brim)....but I did last week knowing I had some miles to do this week and not a lot of time...could brimming it cause the issue ? Is this where I put the car details and a bit about myself ?........
Post #395797 12th Jul 2016 11:34pm
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
Mine did this for about two months then gradually got better, I was going to replace it but never got round to it
Has now been fine for 6+ months (which pretty much guarantees it will break the evening on my drive home from work!) 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #395823 13th Jul 2016 9:20am
n1cktdv8
I am heading to southern france in 2 weeks with the tintent and 4 bikes and a tonne of usual stuff. Wifey has driven it this morning and says the needle went to half tank and stayed there Rolling Eyes she also spoke to our mechanic and he says that the tank needs to come out to replace the sender unit(s). Not a huge job but no good with a full tank. He did say say sometimes they develop a wiring fault so he will take a quick look at the electrics too.
Obviously needs sorting but with just 2 weeks to a main holiday do I really want to tempt fate..... Is this where I put the car details and a bit about myself ?........
Post #395825 13th Jul 2016 9:29am
you dont need that hassle just before your holiday, hope its sorted easily Nick.. ... - .- -.
Post #395828 13th Jul 2016 9:38am
The fix was covered in one of the 2 main LR mags a month back. Discovery 4 HSE
Post #395829 13th Jul 2016 9:41am
n1cktdv8
I like the sound of 'fix'.....it sounds much more accomodating than 'repair'....you dont recall which one Adam do you ?
Thumbs Up Is this where I put the car details and a bit about myself ?........
Post #395831 13th Jul 2016 10:15am
Bigglez
2016 Range Rover Autobiography SDV8 Carpathian Grey
This has just happened on my MY10 TDV8 - feels oddly even worse when its a TFT screen that's telling you..
is this a main stealer job or something my local place (not a specialist but does some work on friends RR) could do?
Post #416926 6th Dec 2016 9:22pm
Spelunker
England 2003 Range Rover Vogue Td6 Zambezi Silver
I have read that you can access the sender units by removing the inspection plate under the rear seat...... QUID FACIUM TIBI
ANTEQUAM ALIIS
2003 TD6 VOGUE Zambezi Silver
tows 2006 Lunar Delta 540/2
Post #416934 6th Dec 2016 9:40pm
Yes you can but some carpet has to come out first. There is nothing that can't be fixed with a hammer😜😜
Post #417044 7th Dec 2016 7:12pm
