Home > Maintenance & Mods (L322) > What can go wrong next, timing guide failure this time
Covbandit
United Kingdom 2003 Range Rover Vogue 4.4 V8 Oslo Blue
Timing guides have failed on my 4.4 2003 m62, does anyone have or know of somewhere l can hire the engine locking set, l have managed to get all the parts down to 210 quid which is a mixture of genuine land rover, genuine bmw and febi bilstein. The locking kit is nearly as much again and due all my recent issues funds are depleted. It wont be until sometime in august or septemberad got some saving to do now
Thanks
John
Post #396171 15th Jul 2016 9:34am
Zebedee
United Kingdom 2013 Range Rover Vogue SDV8 Santorini Black
I'm not sure if I'd recommend it, though it is possible to do the job with out them.
I believe there are 2 parts to the set. One part is the pin that locks the flywheel, and this is useful to get the crank bolt out. I've removed this bolt without the pin by using a stillson and a really long bar on a 1" socket - the bar needed to be about 6-foot long and wasn't easy.
The other part locks the cam shafts in place at 90-degrees to the head. I did this part without locking them and being careful to make sure they didn't move far and then re-installing the chain making sure the blocks at the rear were at the correct 90-degree angle.
It worked fine, though others might say I was lucky.
Have you seen this article which is very good? www.bimmerboard.com/forums/posts/876903 The blocks at the rear of the cams can be seen in the pictures of section 28. Current:
- 2017 L405 3.0 V6 Autobiography
Sold:
- 2013 L405 4.4 TDV8 Vogue
- 2004 L322 4.4 Vogue (BRC LPG)
- 2002 L322 4.4 HSE (having fixed timing chain guides)
- 2000 P38 4.6 Vogue (BRC LPG)
- 1981 2-door In-Vogue
- 1980 Ex-Army SIII LWB
- 1976 SIII LWB
- 1968 SIIA
Stripped for parts:
- 2003 L322 4.4 Vogue
Post #396181 15th Jul 2016 10:47am
ndg
United Kingdom 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Can you post a list of the parts and where you got them from? A friend is about to do this on his 7 series and the vanos on ours is starting the start up rumble. If im in fixing that I'll do the timing guides at the same time!
Post #396184 15th Jul 2016 10:58am
ndg
Also:
http://www.ebay.co.uk/itm/BMW-X5-4-4-4-6-E...SwKPNTyorQ
or:
http://www.ebay.co.uk/itm/LASER-ENGINE-TIM...XQh8NTd8XB
Post #396185 15th Jul 2016 11:00am
Covbandit
Hope it works but below is my notes with prices, its a case of mix and match, think l highlighted the cheapest
Thanks for all the advice and l am tempted to have a go with the basic cheap locking kiy, but will decide more when its torn down. Thanks for all the help so far.
Post #396189 15th Jul 2016 12:07pm
Covbandit
The only thing not there is the tensioner, added this later and that is lhp000050 about 40 off ebay so 250 in total
Also from lr for all the above with vat and tensioner is 436.25 and about 20 quid cheaper from bmw
Post #396190 15th Jul 2016 12:11pm
Covbandit
PLEASE NOTE l got these part numbers for my 2003 m62 vanos engine, please check any part numbers yourself to make sure they are correct for your vehicle. A 7 series may have th n62 engine so dont know if will be the same, also the last bmw part number above is for the timing chain, he said the number was 1 digit out but stl found the part.
Thanks
Post #396192 15th Jul 2016 12:16pm
ndg
Thanks
Post #396195 15th Jul 2016 12:28pm
Covbandit
Ok all done, carried out timing chain rebuild on the august bank holiday weekend, only help needed was for someone to put the locking tools on the back cam. The inlet cam on the pass side had jumped 2 teeth. All in all with filter, gaskets, timing location kit, oil and parts the whole job cost a little over 500 pounds. However some points to note for anyone tackling the job.
Make sure you remove the oil strainer which is accessible when removing the sump plate as it was blocked by old timing guide parts.
When removing the timing cover make a cardboard template and put all the bolts into the corresponding holes, as they are different lengths.
I did not remove the main sump or gasket, the gasket is metal so just used some good quality sealant where the timing cover joins.
The front pulley is very tight, once all other parts are removed there is enough room to get a pair of stilsons on the body of the pulley and will lock out on the chassis, then use a decent bar. It did leave a couple of marks but cleaned straight up and could not even tell.
First start was a bit scary but once oul had got round it sounded sweet. 600 miles now and the engine is whisper quiet, super smooth and oil leak free.
Vid of engine first start here, there was a distorted washer on the belt tensioner that was rubbing slightly and the camera had some oil contamination on the lens so sorry for the blurry picture.
Post #406146 24th Sep 2016 9:22am
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
It did sound a little scary on first start. Bet your glad you got that job out of the way though. 2004 RR 4.4 V8 Autobiography
Post #406151 24th Sep 2016 9:48am
Covbandit
Yep, when she first rattled to life my heart just sank. It sounded exactly the same, but I sort of expected it if that makes sense. But even so it was nerve racking. But very glad its done, especially knowing that this is one of the more common issues, at one point I just wanted to give up as it peed it down all weekend with only a gazeebo as cover, as if being in a wheelchair was not challenging enough! But anyone attempting it should just take their time with it. Looks daunting when stripped but access is amazing.
May be a coincidence but I did an oil change a month before it went and used mobil 1 new life 0/40. The guides collapse shortly after this so do not know if this just highlighted a weak hydraulic chain tensioner causing the failure. But using slightly thicker 5/40 from now on.
Post #406156 24th Sep 2016 10:21am
mattyp
how many miles had it done?
Post #406256 25th Sep 2016 8:33am
Covbandit
It had just done 101k, I have only done 3k in it so was alitrle disappointed. But I now know it should last a good few years with regular servicing.
Post #406290 25th Sep 2016 11:31am
mattyp
Will these tools work ?
https://www.ebay.co.uk/itm/322112871997
Post #406731 28th Sep 2016 5:55am
Covbandit
That kit will lock the cams and flywheel so in theory you could get away with it, however this kit http://www.ebay.co.uk/itm/BMW-M60-M62-CAMS...&rt=nc is the kit I bought. That way you can make sure your vanos units are in the correct position and also has a manual timing tensioner to allow you to check the timing under tension. This one was an auction. He does sell them buy it now.as pointed out to me its not worth the risk of having your vanos units a tooth out.
Post #406741 28th Sep 2016 8:59am
