![]() | Home > General > Goods carrying... |
Giantlandyman Member Since: 25 Nov 2015 Location: Essex Posts: 800 ![]() ![]() ![]() |
I think the most important factor in this is driving with the tailgate open. Even if it is raining, all windows must be fully open and if you have it, I would tilt the sunroof as well....
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8059 ![]() ![]() ![]() |
If they are lying flat, I wouldn't have thought excessive weight on the tailgate - I would have thought a block would concentrate the weight more.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1511 ![]() ![]() |
I've driven with loads hanging out the tailgate. Those have been ones where the bottom tailgate is down and the upper one is in the closed position.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
if you have the tailgate down you can't see the reg number which is illegal.... ... - .- -.
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1417 ![]() ![]() ![]() |
If you have a towbar you'd be better hiring a trailer.
If the rear seats are down and the beams pass over the hump you'll put more weight and stress on the lower tailgate straps thanif you use even 1/2" riser blocks before the tailgate flap. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
I don't reckon the sleepers will be much more than 50kg each. I have just had some 9"x4" oak beams to make mantles out of, they were easily man portable. I don't think loading will be an issue. The load Bed with the seats folded is only about 1.7m so they will stick out of the boot about 900mm so should overhang the tailgate by about 200mm appx.
Terrier Member Since: 17 Dec 2015 Location: Yorkshire Posts: 51 ![]() |
Thanks for the replies guys. I've got a witter bike rack for the tow bar, so shall use this to give her that extra length, as well as keeping the number plate visible.
