![]() | Home > Maintenance & Mods (L322) > Gearbox Issues |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8714 ![]() ![]() ![]() |
Never had one, AFAIK they run cooler in anything else.... Pete
Danwilderspin Member Since: 15 Jun 2016 Location: Cambridgeshire Posts: 2246 ![]() ![]() ![]() |
Hi Guys,
is this the correct oil cooler for the gearbox?
Please somebody save me from tearing my hair out!!!
Bump |
PaulTyrer Member Since: 22 Jul 2013 Location: Devizes, Wiltshire Posts: 1262 ![]() ![]() ![]() |
Had a similar sort of problem with ours not long after we bought it, long story short, the gearbox was 'rebuilt' when we bought it as there was an oil leak, so the dealer had it done. Anyway, not long after we got it, we found that reverse gear seemed a bit 'slow' to engage then it started going in with a bang, subsequently we got to the stage where we were revving the |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
I think what PaulTyrer has suggested is certainly a possibility. If your upper valve body has cracked ‘in the usual place’ this will cause the transmission to effectively drop into neutral (due to loss of hydraulic pressure on the A-clutch) when you have Drive selected at tickover but then when you apply the throttle the increase in engine revs produces sufficient flow from the transmission oil pump to overcome the leakage and the clutch engages with a bang and you’re away. When cold, the higher viscosity of the fluid means there’s less leakage and the pump can keep up, so there’s no loss of pressure to the clutch.
Phil,
Guys - it's still is rolling forward and backward when stopped as you'd expect does that feed the theory either way? Reverse engages very quickly as expected? Thanks |
The ‘usual’ upper valve body crack - which, to be honest, is very rare on later 5HP24 models like for the L322 - is in the worm track between Shift Valve 1 (SV-1) and the F-clutch valve (KV-F). This circuit is pressurised in Park, Neutral and 1st gears only. It would therefore have no effect on reverse (i.e. Paul’s issue must have been elsewhere) but I would expect you to lose forward creep at idle. So you still have to hold the car on the brakes to stop it moving forward at idle in Drive, even on a slight uphill slope?
How do you define slight up hill in a multi story car park it doesn't creep but I would say that's quite steep? |
Phil, checked the oil as I didn't top up after changing oil cooler as nothing came out the pipes then it clicked that the cooler held about a litre of oil so I topped it up and it was about a litre and a half down.
Maybe (hopefully) the issue was just the low fluid level then (though you would expect the same issue in reverse in that case).
Great thanks
