Home > Wheels & Tyres > Dealer fitted different sized rear wheels
FrankRizzo
Germany 2012 Range Rover Vogue 4.4 V8 Santorini Black
In my last post I asked for opinions on whether to go with Contis or Pirellis for a pending rear tyre pair replacement as a result of getting a screw stuck in one. This was shortly before I was about to drive the car to the French Alps on holiday.
I decided on the Pirellis but it wasn't until I got to my destination that I noticed the dealer had put 255/55R20 tyres on the back whereas the existing Contis on the front were 255/50R20.
Is this a problem? One reader suggested on my previous thread that it could stress the centre diff. Would the dealer have just made a mistake or don't they consider this a problem? Admittedly we did discuss swapping the front Contis soon as they are also wearing on the edges but that wasn't to be done until I put the winters back on in October.
255/55R20 doesn't seem to be a standard L322 tyre according to various websites. Indeed, Pirelli's own website doesn't suggest the size for my vehicle, only recommending 255/55R19 instead...
I have an upcoming appointment to replace the front brake pads so I can get them to swap to the correct tyres if necessary.
Could it be that Pirelli don't do 255/50R20 any more so the fitted 255/55R20 instead? Is that OK for the L322? Won't the dealer have to recalibrate the speedometer?
If 255/55R20 aren't a problem I'll just have them put on the front as well.
As you can might notice I'm not that clued up on the intricaies of tyre choice so I appreciate any advice you can offer. Thanks Thumbs Up 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
2008 Vogue 3.6 TDV8 automatic (LHD), Java Black
Post #396402 16th Jul 2016 6:47pm
could be a genuine mistake by the dealer...i would get the proper size fitted when you next visit [255 50 20] ..
your insurance company might not pay out if you have odd size tyres fitted and of course having the '55' profile will affect the speedo reading.. ... - .- -.
Post #396403 16th Jul 2016 6:52pm
It's the different size front to rear i'd be worried about.
55's are standard on the L405 - it's 50's for the L322 - so both are Range Rover sizes, but any reputable dealer should have checked.
Post #396408 16th Jul 2016 7:22pm
GraemeS
Australia
Different sizes front to back will cause a problem with the centre diff so make them the same ASAP. I'm surprised it hasn't already thrown ABS sensor faults too.
I have 275/5520 and my speedo is spot-on although the odometer will be reading low. However my speedo's market specs are the most optimistic whereas your's might be less optimistic and therefore your speedo may read slow.
Post #396429 16th Jul 2016 9:48pm
FrankRizzo
Can the dealer adjust the speedo and odometer accordingly? Is that something they can do? 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #396454 17th Jul 2016 10:02am
no ,the speedo cannot be adjusted.. ... - .- -.
Post #396455 17th Jul 2016 10:10am
either put the correct size on the back 255/50 or the new size on the front 255/55
lots of folks seem to be using the 55 ratio size now, but personally I would get the right size changed over by the dealer. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #396760 19th Jul 2016 5:54pm
FrankRizzo
Got the car back today. The dealer put two 255/50R20 Pirrelis on the rear so all is good again. They didn't charge for the labour Thumbs Up 2012 Vogue 4.4 TDV8 automatic (LHD), Santorini Black
Post #397036 21st Jul 2016 7:24pm
