Home > Technical (L322) > Help Please Red light on dasah its all dead
Bingy
England 2010 Range Rover Vogue TDV8 Bonatti Grey
So i set off this morning to exchange the tintent.
Coupled up and drove to dealers 25 mile down motorway
Dropped old caravan off
Pulled out of caravan place noticed red battery light on
Pulled over belt looked ok
started up redlight still on
Proceded down motorway started to get all sorts of messages
ABs, HDC inactive etc
airbag light came on
trans prog failsafe
managed to get off motorway
but no power
brother had to push with engine on up hill @1mph
dash message centre dissappeared
Managed to get onto drive
Turned off and locked up
Having looked at a few threads does this mean my alternator needs replacing
or is there a fuse that may have blown asi i also had the caravan plugged in
without the battery in the caravan ooops
Is there anything i could check battery is now as flat as a pancake
cheers
Post #396482 17th Jul 2016 2:07pm
new battery and then check the alternator.... ... - .- -.
Post #396483 17th Jul 2016 2:10pm
Nicka2311
Scotland 2005 Range Rover Vogue Td6 Java Black
Sounds like an alternator failure as the battery light is triggered by the car's voltage dropping below the normal engine running charge or a significant drain on electrical system.
If you have a voltage meter, jump start the car and place the voltage meter on the battery, should indicate 14v or more to signify a healthy alternator. Once the car is off, keep the volt meter on the battery. It should maintain 12v if this drops quickly, your battery has had it. '55 Java Black Vogue
Post #396484 17th Jul 2016 2:23pm
Bingy
Thanks for quick reply Stan Thumbs Up
Post #396485 17th Jul 2016 2:25pm
its bad to leave the caravan leads loose as they will be live direct from the car via a fuse as soon as the car is switched on. There is nothing that can't be fixed with a hammer😜😜
Post #396496 17th Jul 2016 6:11pm
Bingy
Update
Thanks for the replies
As i was away with work, my local indie had the job of recovering the RR off the drive and to their workshop.
Armed with a fully charged battery, managed to get to their premises and do some tests.
Turned out to be the Alternator, only putting out 8 volts
So new alternator with 12 moths gtee
Also got them to put a new expansion tank on, (as i was sick of seeing the 'Check Coolant level' on display).
Coolant flush and new Antifreeze
total £369 Thumbs Up
All back to normal again......... Laughing
For now Rolling with laughter
Post #397949 27th Jul 2016 5:13pm
PaulTyrer
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
Bloody Hell!
Where did you get an alternator for 300 quid! Ours let go a year or two back and it cost us I think around £800 as its the water cooled BMW one!!
Post #397953 27th Jul 2016 6:18pm
Bingy
Mine is also the water cooled version.
The mechanic sorted everything out for me, i just left it with them for the week.
Looking at the receipt, the alternator was actually £264.00 nett.
He also showed me my old one and the expansion bottle at the same time as i picked the RR up.
Always looks after me, and i also try and look after him for servicing, mot time etc
But he does like pound notes
Post #397955 27th Jul 2016 6:33pm
PaulTyrer
Great stuff! Ours went to the main LR dealer in Swindon o the back of a recovery truck! I was working away at the time.
Post #397961 27th Jul 2016 6:56pm
I paid £180 last xmas for a Bosch remanufactured one, I recon £800 must be a brand new one.... Thumbs Up Pete
Post #397970 27th Jul 2016 8:06pm
Clivefog
I got a Denso one for £400 from Euro Car Parts last Christmas.
There was a cheaper one for £250 ish RTX I think?
Post #397994 28th Jul 2016 7:40am
PaulTyrer
Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad Evil or Very Mad
Post #397995 28th Jul 2016 8:03am
