![]() | Home > Technical (L322) > Help - loads of warnings |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2711 ![]() ![]() |
The symptoms suggest low voltage so likely a failed alternator/generator. |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
What he said above. Check the voltage at the battery with the engine running, anything less than 13.5V is likely to be an issue with the alternator. |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Bet your car has done about 80,000 miles! |
Blackbird51 Member Since: 22 Sep 2011 Location: Portadown Posts: 39 ![]() ![]() ![]() |
Fully recharged the battery. Showing 13+ on voltmeter. Went for test run. All warnings back on. Got back to house stopped engine and checked voltage - now 11.0v. Wont restart. Back on charger.
What is the voltage at 1100 rpm?
Left car with local independent. It appears it's not the alternator. Common fault on list is failure to communicate with abs ecu. He has checked it but no faults show up.
Hi all
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8042 ![]() ![]() ![]() |
Always good when it's nothing major |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3839 ![]() ![]() ![]() |
Sounds like you have found a good local independent garage. |
Yep. He trained and worked for local main dealer prior to setting up on his own. He only deals with Land Rover - mainly Discos and Sports - apparently they give the most problems.
