Home > Technical (L322) > ...
FleXzoR
Belgium 2016 Range Rover Autobiography SDV8 Santorini Black
... MY2008 Buckingham Blue Supercharged - gone
MY2016 Santorini Black 4.4 SDV8 LWB AB
Post #397165 22nd Jul 2016 5:57pm
Well that looks much worse than mine, has it got a towbar, I bet someone in it's early life launched a boat in sea water and dipped the back of the FF in the water....
Or you've had a leak for years.... Pete
-Click here for Thread-
Post #397166 22nd Jul 2016 6:02pm
FleXzoR
Nope, no towbar...
Must check for a leak then. Is there a comon leak here somewhere?
Btw rust is at rear wheel arche where metal from body meets rear bumper MY2008 Buckingham Blue Supercharged - gone
Post #397167 22nd Jul 2016 6:05pm
Yep, recognise the area, it's a very common leak area, either the rear side window seal or tailgate seal and water gets to there...
If it's through to the outside then cutting out and welding in new is the only proper way to repair it, at least you can access both sides easily... Then flood the inside, and all surrounding area in rust preventer of your choice...
Also, check the other side for the same.... Pete
Post #397169 22nd Jul 2016 6:20pm
FleXzoR
Will search for leaks then, must be something that is going on for years then..
Cutting the bad spot out and welding new metal plate in place would be indeed the best thing.
How can i check the rear window seals? MY2008 Buckingham Blue Supercharged - gone
Post #397175 22nd Jul 2016 6:52pm
Hose on the outside and see where/if it comes in... Pete
Post #397177 22nd Jul 2016 7:34pm
rar110
What area is in the pic? ______________________________
Post #397196 22nd Jul 2016 9:45pm
Rear of the rear wheel arch inside the boot, passenger side (RHD)
Silver part is the covering on the arch itself..... Pete
Post #397227 22nd Jul 2016 11:24pm
FleXzoR
Yes indeed, straight behind the subwoofer. MY2008 Buckingham Blue Supercharged - gone
Post #397251 23rd Jul 2016 8:30am
FleXzoR
Searched today for water ingress but it is not very clear where the water is coming from.
I removed the subwoofer and dvd systems. In mean time i sprayed with water on the rear quarter. There is water coming in but not clearly where from. The rear suarter plastic is held with 4 plastic clips on the rear and 4 on the side. If i am right, there were only 3 plastic clips on the side installed. Maybe this is were the water enters easily.
I will buy silicone /tec 7 and start to seal the rear quarter window and every hole and plastic clip i see..
I mean time i found out that also my sunscreen drains where blocked. MY2008 Buckingham Blue Supercharged - gone
Post #397321 23rd Jul 2016 5:45pm
