Home > Technical (L322) > [ SOLVED ] Door open message even though doors are closed.
Page 1 of 3 123>
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi all and sorry if this has been done to death but I can't find a definitive answer to this annoying problem.
I bought the Range Rover 4.4 V8 petrol a week or so ago and everything has been fine... Up till now that is. Went out this morning and unlocked the car with the remote, opened the door the interior lights went off? Shut the door the interior lights came on, started to drive the car with the interior lights on and a message banging away on the screen ' door open '. As you would expect the suspension is now inactive and I'm being told by the car to keep the speed down.
I suspect a dodgy latch but which one? Knowing my luck I'll start at one door and eventually find the problem at door number 4!! I'm just after a good bit of advice from you venerable lot to point me in the right direction of the dodgy latch or whatever else it may be.
Thanks in advance
Post #397204 22nd Jul 2016 10:05pm
Open and slam all the doors, boot and bonnet a couple of times, you may find it goes away... If not try a battery disconnect (see WIKI)
If not you need an IID tool or similar to help diagnose which one, or you will end up just changing stuff for the sake of it... Pete
Post #397220 22nd Jul 2016 11:03pm
UK Marine
Hi Pete, thanks for info but I've tried the slamming of the doors, so much so that my neighbours must have thought PMT was finally kicking in.
Interestingly I haven't tried the bonnet.....I was thinking as you have suggested a diagnostic solution but wasn't sure if they were indepth enough to diagnose a door open fault.
I was thinking the allcomms from Storey Wilson was the way to go, what do you think?
Cheers
Post #397221 22nd Jul 2016 11:07pm
Personally I wouldn't have one, the IID is the class leader and does everything the dealer can do and more, the back up from GAP is superb...
They are expensive to start with but if you do a lot of repairs yourself they will soon pay for themselves and they are always worth a good amount should you sell the FF.... Thumbs Up Thumbs Up Pete
Post #397226 22nd Jul 2016 11:21pm
UK Marine
Thanks for the advice, I'll have a poke around on the Gap site..... ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #397229 22nd Jul 2016 11:31pm
UK Marine
I've decided to go for the IID Tool as it seems to give the best all round performance for the price. The problem still remains with a latch I think, can't check which one as I don't have my IID yet but I did strip down the drivers side today but no change.
One thing I have noticed is that the centre button that operates the central locking isn't working. I'm just wondering if this is because a door is being reported as open and has disabled the function, can anyone clarify?
If not then it looks like the BCU might be playing up and require a kicking - errm sorry a reset to default settings.
Cheers ______________________________
Simon
Post #397632 25th Jul 2016 7:50pm
Do your indicators flash once when you lock the car with a key fob?
Post #397636 25th Jul 2016 8:29pm
UK Marine
Yes they do.. ______________________________
Simon
Post #397659 25th Jul 2016 10:28pm
That implies all 5 doors including the tailgate are operating correctly.
The bonnet switch doesn't come into play when locking the car, it only affects the alarm/immobiliser.
The above tends to suggest something is moving when you drive the car due to vibration.
If it was me I'd be inclined to look at the rear tailgate as I don't think any of the passenger doors are likely to move much when driving.
The one thing that might allow the upper tailgate to move sufficiently relative to the lower tailgate is the security of the lower tailgate when locked. when in the closed position is the lower tailgate solidly in position, the two locks on each upper end of the tailgate have a habit of either not locking securely or not locking at all in which case the lower tailgate can move about a bit.
Apart from that you might unfortunately have to wait until you get your IID tool to verify which door is at fault.
Just a thought, how do you know the air suspension is in-active? Are the orange lights off or is the display showing "air suspension inactive"?
Post #397690 26th Jul 2016 8:31am
UK Marine
Good advice thank you. The suspension is inactive as I can't change the ride height at all. I toggle the switch to say - off-road height and the LEDs just flash and no change in height, even after waiting a minute or so, it's the same with access height on either the door button or the suspension toggle on the dash.
I'd like to get under the car to look for a small oil leak but need the car in off-road so I can get under, but........
I'll check the tailgate latches to make sure they are latching securely and report back.
Simon
Post #397694 26th Jul 2016 8:49am
Unfortunately despite what I said above what you say about the air suspension not moving tends to suggest it's one of the passenger doors causing the problem not the tailgate. The tailgate being open doesn't inhibit the air suspension changing height.
What you could do is next time you unlock the car is to get in the passenger door instead of the drivers door and climb over into the drivers seat and then drive as normal and see if anything changes re lights and air suspension.
Post #397696 26th Jul 2016 9:09am
UK Marine
Hi, ok so I've just checked the tailgate and it latches securely with no movement at all, I even activated the latches with a screwdriver to simulate it being shut and no difference.
The thing that puzzles me is that the interior lights come on when I remotely or with the key, unlock the car but they go off when I open any door, then they come back on when I close the door. It's as if the logic has fully turned around.
Everything looks to be working apart from the CDL switch in the dash, the suspension is not working although the LEDs are on, respective to the switch position and the lights are on constantly until it times out at 16 minutes..
Odd one this.. ______________________________
Simon
Post #397697 26th Jul 2016 9:11am
Did you try battery disconnect (often resolves a multitude of sins, resets ECUs and banishes electrical gremlins back in their box (for a while Twisted Evil )) or are you going to wait for your IID Tool to show up? .
Post #397703 26th Jul 2016 9:57am
Weegie
Also it may be the BCU that is causing the problem rather than the doors. I would wait for the iiD tool before going into that.
In the meantime try holding the interior light switch for more than 3 seconds. That should put the interior lights it permanent off but still allow the rear interior light to be used. Not a permanent solution but would avoid the annoyance until you have been able to diagnose the fault.
Doesn't really help with the suspension problem though. John
GAP iiD BT-Sold
Post #397706 26th Jul 2016 10:09am
UK Marine
Hi and thanks for the suggestions. I've tried the battery disconnect but nothing changed so I'm just going to wait for the IID to show up.
I've a sneaky feeling that somewhere somehow it's dropped itself into semi transportation mode, as I'm exhibiting some of the faults associated with it but not all.
Simon
Post #397708 26th Jul 2016 10:21am
Page 1 of 3 123>
