Home > Maintenance & Mods (L322) > Replacing Rear Hub Bushes - How To
Page 2 of 3 <123>
Probably best to get the hub in "wheel on position" before tightening up, under load. .
Post #397598 25th Jul 2016 5:51pm
DoubleRL322
United States 2003 Range Rover HSE 4.4 V8 Zambezi Silver
Ok meaning leave the jack supporting the lower control arm or not?
Post #397601 25th Jul 2016 5:56pm
Yes, but jack to "wheel on" position so in effect taking the load of the car. .
Post #397612 25th Jul 2016 6:38pm
DoubleRL322
Ok thanks! I was able to jack up until the height sensor was completely horizontal. Hopefully thats what you mean.
Post #398827 2nd Aug 2016 2:04pm
johnc10
2002 Range Rover Vogue 4.4 V8 Java Black
Excellent write up. I've just done mine exactly as you have shown. I used the Laser tools but your kit is better and cheaper. My height sensor rubbers had perished so replaced sensors too. I got a hub kit off ebay with bushes, bolts and washers, £90.
Post #402319 28th Aug 2016 1:44pm
andyfid
England 2003 Range Rover Vogue SE Td6 Tangiers Orange
Thumbs Up excellent write up
Post #443934 8th Jul 2017 4:49pm
mm289
United Kingdom 2011 Range Rover Autobiography 4.4 V8 Ipanema Sand
Just did mine this weekend, write up is really helpful.
One thing I would add is when before putting the new bush in clean up the area on the suspension arm that the circlip sits against. There is very little clearance on the clip and if you have rust/crud on the arm it can make getting the clip in a bit tricky.
And just incase you wondered how much leverage it can take to wind in the tool to drive the old bush out......
Shocked
That's my 5ft long commercial torque wrench with me (90kg) on the end. The Snap On windy gun wouldn't touch it!
Cheers,
Paul 2011 TDV8 AB
2006 TD6 AB (Gone to Wales)
Post #466316 28th Jan 2018 10:52am
p38arover
Australia
I'm doing mine on Monday. I've hired the correct tools (made by Laser Tools) from a fellow member of the AULRO forum. Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #466433 29th Jan 2018 10:41am
RRV78
England 2003 Range Rover Vogue 4.4 V8 Java Black
I must of been lucky as I’m doing a rear wheel bearing I pushed the bushes out with my 12 tonne press came out easily for once.
Post #466470 29th Jan 2018 2:29pm
mm289
But that would require taking the lower arm off the car and over to the press. I admit that is my preferred option, but with the lower knuckle on the lower suspension arm that is more hasle than trying to get the bush out in situ I think.....?
Cheers,
Paul. 2011 TDV8 AB
Post #466514 29th Jan 2018 9:16pm
p38arover
Australia
A friend and I replaced the rear upper and lower bushes last Monday.
Look, no rust!
Marked to get the eccentric washer back in approximately thh right place. (The car is having a wheel alignment done as I write.)
Quite easy when one uses the right tools and have access to a hoist. I used the LaserTools http://www.lasertools.co.uk/product/5977 and http://www.lasertools.co.uk/product/5978
The bushes had little to no radial play but quite a bit of axial play, especially the left lower where the play was about 1.5mm. The grease was old and hard and there was a bit of rust in the joint.
The left lower also has two pieces of thin plastic (nylon?) jutting out of it. I assume they were/are the bearing surfaces. As noted above, the "bushes" are Heim/Rose Joints.
and clean upper joint:
Cost A$219 for the parts (incl. post). Ron B. VK2OTC
2003 L322 V8 Auto
2007 Yamaha XJR1300
Post #468240 12th Feb 2018 4:40am
Andy
I’ve just tackled this job. I made light work of it with the Laser 5977 bush tool designed specifically for removing these bushes. The hardest part was getting the old bolts out.
It took 10 minutes to remove the old one inc setting the tool up. 5 minutes to fit the new one.
The tool was £85 but worth every penny. I’ll probably never use it again!
Post #481600 22nd Jun 2018 10:08am
Pawl
England 2007 Range Rover Vogue TDV8 Cairns Blue
I changed them on ours last week too.
Bolt removal was a real pain.
I had to buy a cheap Screwfix reciprocating saw & loads of metal cutting blades to cut out siezed bolts on the top 1 side, bottom the other side & both toe control arms. I couldn't get my angle grinder in at all.
The bottom joint was horrible access & took more than hour to cut out, with repeated blade changes as the bolts are high strength & I was working on the drive.
Lots of very puzzled stares from passing neighbours - lol.
PS when re-assembling the toe control retaining bolts in the subframe I decided to fit them the opposite way round to standard, so the nut was at the rear, easily accessible with a socket for tightening . It seems easier to hold the bolt head with a ring spanner in the narrow gap in the subframe front. Paul,
2001 Discovery 2 TD5, 211,000 miles & climbing
2006 FFRR TDV8 Vogue 151,000 miles & now sold
Member of Midland (Land) Rover Owners Club, www.mroc.co.uk
Post #481603 22nd Jun 2018 10:40am
Andy
The bolts on mine were seized in good and proper. I had to use a large drift on an axle stand with a sledgehammer to bash it. Once it was finally out it was full of rust. I cleaned it up on a wire wheel but decided in the end to get a brand new one. Not worth the risk because if that fails, the hub comes away for the wishbone and that’s a disaster.
Post #481606 22nd Jun 2018 10:57am
Pawl
I was unsuccessful with a large lump hammer on 1 of the the siezed bolts - although the nut came off relatively easily.Hence the saw.
I thought I'd make a start on the other side by loosening & re-tightening the bolts, ready to tackle it the following week.
The top bush bolt came loose easily.
Too my horror, the bottom bush bolt nut initially wouldn't budge, but then just snapped off - leaving me with an unusable car unless I cut it out & replaced the bushes. Shocked Paul,
Post #481607 22nd Jun 2018 11:07am
Page 2 of 3 <123>
