![]() | Home > Duckworth Parts > Wiper arms and seatbelt buckle |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 ![]() ![]() |
Afternoon
unsolicited Member Since: 30 May 2016 Location: Bucks Posts: 130 ![]() ![]() ![]() |
Payment sent, thanks!
arms should be fine, only one part number available now across the range... You can paypal direct using - www.paypal.me/duckworthparts
Hi Dan
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8798 ![]() ![]() ![]() |
I think you will find that the piece stuck on your original wiper fitting on the FF is already on the new arm, it will be partially stuck on due to the paint, it should come off with some persuasion and then you can change the one on the FF, if you can get it off as they usually corrode on and need a puller, or discard it and bolt the new arm to the old fitting....
Thanks for that. The new one is definitely a single assembly, but I recon you might be right that the new arm replaces the old two piece fitting method. Hope Dan can confirm - I'll then get a puller to the old billet next weekend. |
Oh right, they have changed them then...... good luck getting them off, needed a large puller, tightened it until it was maxed out then had to hit it with a club hammer 1/2 dozen times to get mine off, they really do stick on well.... |
Ahh. Puller & club hammer. Sounds like a great way to spend a Saturday morning. Looking forward to that (not) |
I suppose seeing as you don't need that bit you could Dremel it off, maybe easier... |
Can confirm what Pete has said, needs pulling off |
Thanks everyone for the suggestions. Will go the puller route on Saturday & see how I get on. |
Start spraying it now with some PlusGas... |
Just for reference to those who are replacing their rusty arms. The new ones do fit straight over the spindles with no adapters. A 3 legged puller removed the passenger side aluminium billet with a bang - but no space to fit it driver's side. My 2 legged puller wasn't man enough so will try again with a better one when it arrives.
M4TT53 Member Since: 24 Dec 2016 Location: Devon Posts: 19 ![]() |
Sorry to hijack. But can the billet pieces be re-positioned?
