Home > Maintenance & Mods (L322) > Rear main seal Oil leak on L322 4.4. |
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 |
Craig at Cam-Tech
19th Jul 2016 10:59pm |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 417 |
Gearbox removal is certainly doable on a drive although I did it in my garage. It's easier to remove the transfer case off the back first to lessen the weight (I learnt my lesson on that one, I was doing it on my own and both together were too much). Even then a proper transmission jack helps a lot. Given the room underneath to work it's actually fairly straightforward...far easier than an Integrale gearbox
20th Jul 2016 12:38pm |
Madmax676 Member Since: 25 Jun 2016 Location: Somerset Posts: 44 |
Thanks for the reply. Did You put the front up on ramps or does the car need to be level when raised? |
20th Jul 2016 5:37pm |
I raised both the front and rear on ramps just because I had them and I wanted to make life as easy as possible underneath with the ability to have enough height to be able to move the transmission under the sill to outside the car.
20th Jul 2016 10:46pm |
Spot on bit of info, thanks |
21st Jul 2016 10:31pm |
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 |
Hi mate
23rd Jul 2016 1:41pm |
kimlahti Member Since: 14 Oct 2015 Location: Oulu Posts: 85 |
Hi, did you check the oil return pipe pair that runs down to sump near starter motor? -08 3.6 Vogue
24th Jul 2016 8:32am |
The ramps I have are these:
24th Jul 2016 10:41am |
Hi, yes I run my hand down it and all appears dry. ive also poked a small borescope camera up around the back of the engine and can't see anything obvious. I've got a new set of cam cover seals so am going to change these anyway and also stick a new set of plugs in over the next few days - just to eliminate them before going big and dropping the gearbox. |
24th Jul 2016 7:04pm |
After reading again.
If it was inside then possible leaks are: 1. rear main seal or it's cover 2. main oil channel plug below coolant cover 3. Upper sump gasket. No easy options. -87 951 |
25th Jul 2016 12:51pm |
There doesn't seem to be much fresh oil on the sump so don't think it is coming down from the block - new cam cover gaskets, a good clean and a hand full of talc thrown around it to spot the leak at the weekend I think. Done this a few times on other engines and it worked well. |
25th Jul 2016 11:07pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 7956 |
Just remember gearbox oil in the 5HP24 is very similar to clean engine oil, sort of straw coloured, not red like most ATF fluid... Pete
25th Jul 2016 11:56pm |
New cam cover gaskets fitted today and gave it a new set of plugs while in there. All looked good to be honest however all of the gaskets were quite hard. Had a good look around the back of the engine and no obvious signs of a lot of oil.
31st Jul 2016 8:00am |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 |
Out of interest what engine oil are you running?
31st Jul 2016 1:27pm |
