Home > Maintenance & Mods (L322) > Alarm
Page 2 of 3 <123>
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Or disconnect the negative terminal and leave it, shouldnt do any harm Thumbs Up
Post #397662 25th Jul 2016 10:32pm
rangeseb
United Kingdom 2006 Range Rover Vogue Td6 Java Black
No rain! Just hot hot weather.
I was asking about the battery before didn't know if it was safe to disconnect.
I do wonder if it is the heat messing with the car.
I'll let thw Wife carry on as normal tomorrow and if it plays up I'll get her to spray it with WD40 (easy job for her) onto the bonnet latch.
Post #397665 25th Jul 2016 10:45pm
Madmax676
England 2003 Range Rover Vogue 4.4 V8 Java Black
rangeseb wrote:
Does anyone have a picture of what I should be disconnecting?
So far so good 10:25 in the PM and nothing.
Mine is one of these located in the opposite compartment to the battery
Post #397667 25th Jul 2016 10:46pm
Madmax676
It goes open circuit when the bonnet is closed so fine to disconnect by just unplugging it
Post #397668 25th Jul 2016 10:49pm
rangeseb
Madmax...
When you say oposite to the battery, you mean top left corner of you are standing infront of the car? (Drovers side)
From my research on you tube the switch everyone is talking about changing is the bonnet latch (the one where you move your hand to open the bonnet)
Post #397672 25th Jul 2016 11:40pm
rangeseb
Just been thinking.....(Dangerous i know Shocked)
as it stands the car has gone radio silent and back to normal.
these are the two switches people have spoke about online and here. For a quick fix can i just disconnect both until i get replacements in a few days if the alarm starts going crazy again?
Cheers
Post #397721 26th Jul 2016 10:59am
the problem switch is the one that tells you when the bonnet is open [first pic]
its a common fault where outside temperature changes cause the alarm to sound...solution is to strip and clean or replace.. ... - .- -.
Post #397722 26th Jul 2016 11:05am
rangeseb
Stan.....
Where would i find that part in the engine bay?
I'm guessing alone the top of the engine bay Whistle
Post #397725 26th Jul 2016 11:19am
The lower one in the pictures above is the bonnet cable release type switch. I know these are on the Discovery and Range Rover Sport (having replaced some myself).
I am not sure (as I have not looked) if the L322 has both, but I would doubt it.
Just unplug the cable into the plunger switch. Job done. Discovery 4 HSE
Post #397732 26th Jul 2016 12:37pm
rangeseb
But where is the plunger? I cant see it Banging Head
Post #397733 26th Jul 2016 12:43pm
Post #397737 26th Jul 2016 1:05pm
rangeseb
Post #397743 26th Jul 2016 1:21pm
luv2xlr8
United Arab Emirates 2009 Range Rover Supercharged 4.2 SC V8 Bournville
Hi All,
Been a great ride for many months but I find my self happily coming back to the library.
New situation:
1) Reach home and lock car via key fob
2) Alarm comes on 10-15 minutes later with the hazard lights
3) Use key fob to unlock and lock car again
4) Solved
……only for the situation to come back and wake me and the neighbours up late at night Thud
Also
1) When start car or turn off error message "hood bonnet open"
Stan that last pic you posted, is that all I need to do to diffuse the problem?
Can you please confirm how its done exactly? or maybe rangeseb can advise if Stan is on Holiday Cool
Cant wait to put another challenge to bed and enjoy this beast.
Thank you.
Post #415617 27th Nov 2016 7:24pm
just unplug it Thumbs Up ... - .- -.
Post #415630 27th Nov 2016 8:07pm
Fatzo
France 2011 Range Rover Vogue TDV8 Ipanema Sand
bonnet thing...
had this problem with my TD6, alarm going off anytime.
expansion in hot weather
tightened the contactors and voilà!
Post #415651 27th Nov 2016 11:06pm
Page 2 of 3 <123>
