Home > Maintenance & Mods (L322) > Interior Modding...
Danwilderspin
Matt - does that solve the reboot issue that some custom firmware a have? Also I saw maps is that the latest you have ?
Cheers
Next
Updates from yesterday - door cars sprayed and trims (lower) rapped
Now all I have to do the rear cards and the two green trims under the seatbelt but they are plastic welded together Sad
Also only issues I can't seam to fix even with a heat gun is this both sides Smile
Post #397652 25th Jul 2016 9:52pm
Danwilderspin
Black dash top is on there now
Post #397653 25th Jul 2016 9:52pm
DannyH
England 2002 Range Rover HSE 4.4 V8 Zambezi Silver
I'd be tempted to make a small cut or two in the parts where it's creasing to relieve the stress, once stuck down the cuts will be less noticeable than the creases Dan
2002 Zambezi Silver
Men And Motors RR Quote - It's like having wheels fitted to your living room!
Post #397683 26th Jul 2016 7:53am
Sleeper
United Kingdom 2003 Range Rover HSE 4.4 V8 Adriatic Blue
get some heat on the creased area, it should go really soft, then pull it around.
Why not dye the dash with leather dye?
Post #397784 26th Jul 2016 3:12pm
Danwilderspin
The decent dye was about £20 the used dash was £40 and no chance of failure Wink - I tried heating looked lovely then the next morning the creases were back :-/
Post #397841 26th Jul 2016 9:03pm
Joncey
Jersey 2010 Range Rover Autobiography 5.0 SC V8 Santorini Black
You need to use vinyl wrap primer on the edgies it helps it stick
https://youtu.be/ESm6szzkEc8
Post #397865 26th Jul 2016 11:56pm
