![]() | Home > Maintenance & Mods (L322) > AJV8 Radiator Replacement |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
its in our wiki.... ... - .- -.
| Cappo Member Since: 19 Sep 2011 Location: Kent Posts: 537
I'm being dense here Stan, I really can't find it. Would you mind pointing me in the right direction please? |
http://www.fullfatrr.com/forum/topic16155.html ... - .- -.
Ah yes, I had seen that one - but that's for the BMW V8? Is the rad & fan setup the same on the AJ? |
you got me there ..i think the basics should be the same ...
Found the link, I'll try and download that later and check, thanks. |
| jam220 Member Since: 08 Jun 2016 Location: Atlanta Posts: 31
same procedure i just did this. Summary: drain coolant, take off the fan and remove with the shroud (remove the bolt that bolts the trans cooler to the shroud), remove upper and lower radiator hoses, loosen the two plastic screw type things on the upper radiator support that hold the top of the radiator in place, remove radiator. |
Been looking into this a bit more, as I'm going to have to do it next week I think. The general instructions and videos on the web are quite straightforward....however |
it is possible, that pipe do flex to a certain extent. Just work it and it will clear it |
Thanks, I shall check whether the spanner which I think I have is the right size, take a deep breath, and crack into it then! |
| Jupiterrover Member Since: 27 Sep 2016 Location: Florida Posts: 12
I have this same question for my 2006 L322 Supercharged. Replaced the radiator on my 2003 L322 (BMW) no problem but the 2006 looks more involved. |
I've done it and it is possible! Really busy at the moment but I'll try and write it up shortly. I did it by removing the slam panel (which is easy). More to follow |
Right, here you go:
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1561
Nice one. I'm just about to do the same job. I think I might take pics or video it and I'll put it up for a wiki post if wanted. V8 or else ... |
